Thread: Compression
Results 1 to 7 of 7
  1. #1 Compression
    Senior Member Aleksandr Frayman's Avatar
    Jan 2017
    MOSCOW
    I have Weapon 8k and I have a minimum compression of 4: 1 on 8k WS. Why can not I make 1: 1? Or how can I do this?
    Senior Member Chad Lancaster's Avatar
    Nov 2008
    Simi Valley, CA
    you've got to lower the fps
    Chad Lancaster
    ICON Motion Pictures
    The Southwest
    www.thesouthwestfilm.com
    www.fb.com/thesouthwestfilm
    Instagram: https://goo.gl/6cElQF
    Nov 2011
    Brooklyn
    That's as low as it can go. To get less compression, lower your K's. 4:1 is almost lossless/uncompressed anyway.
    Nick Morrison
    Founder, Director & Lead Creative
    // SMALL GIANT //
    smallgiant.tv
    Nov 2008
    Simi Valley, CA
    I don't have a helium in front of me but based on Phils chart you can do 2:1 at 1fps
    http://phfx.com/tools/REDCamAssist/R...&fps=1&HDRx=no
    Chad Lancaster
    The Southwest
    Heh. You all beat me to it :)
    But TL; DR version.
    REDCODE RAW is RED's variable compression ratio raw codec and you have the ability to set your compression ratio. It's lowest compression level/higher data rate are tied to the media used in camera as well as the internal bandwidth. Lower compression ratios = higher data rates = less recording time on media. Higher compression ratios = lower data rates = more recording time on media. Additionally when you film higher frame rates you'll notice your compression ratio is still tied to your data rate, so higher frame rate will typically result in a higher compression ratio (more frames per second recording).
    Most productions still to this day employ 5:1 through 8:1 compression ratios to receive a nice high quality lower compression ratio image. I would say 10:1 through 12:1 is also great if you are oversampling in particular. I know people who go further still, but to each their own. There have been notable improvements over the years with REDCODE RAW over the years that have been directly tied to the relationship between advancements in sensor technology, processing power in the camera brain, changes to the internal camera image pipeline, and even improvements in the optical path. At the moment DSMC2 cameras produce the highest quality REDCODE RAW encoded stream with various sensor technology.
    2:1 is the lowest compression ratio available in camera. Between 2:1 and 3:1 you are at visual losslessness compared to an uncompressed stream and still reaping the benefits of a smaller data footprint.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Jan 2013
    Red doesn't do uncompressed at 24FPS. 2:1 is technically lossless (meaning you don't lose any visual data). 3:1 and beyond you will lose image data, resulting in more artifacts as you increase compression.
    Red's broadcast module might output uncompressed, but i'm not sure.
    Senior Member Jarek Zabczynski's Avatar
    Poughkeepsie, NY
    I've stayed between 5:1 and 8:1 on Dragon, usually 8:1 - 12:1 on Helium.
    Shoot for the Impossible...Then do it.
    Jarek Zabczynski
    Director / Editor / Cinematographer
    Weapon 8K | www.jarek.com | WE'LL BE ALRIGHT (Music Video) | BAJO EL SOL (Music Video)
