Click here to go to the first RED TEAM post in this thread.   Thread: RED DSMC2 Tactical Top Plate now shipping
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    Quote Originally Posted by Brent@RED View Post
    Think of this like Lemo Adaptor A, redirected pogos to Lemo. Cannot do both redirect plus pass-through...
    Why? What is the reason that you can NOT do both. If you say impedance, then you are wrong. These are digital signals.
    Quote Originally Posted by Neil Abeynayake View Post
    One consideration would be additional hardware required to either have priority, switch, or disable the menu system between two connected displays. Power draw could be also consideration.
    Either way, the additional components would add cost.
    Not saying that's why, but certainly possible reasons.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Donald MJ Anderson's Avatar
    Aug 2014
    Ontario, Canada
    For WC there is a market for a pass through as they have two versions. As mentioned a combo top plate would likely cost more $. I think an extra 15% - 25% to get the functionality/flexibility would be a nice option over RED making a second top plate with pass through. I`d pay a bit more if it meant not swapping out top plates. Ideally a smart top plate that can auto detect signal and route as needed or worse case a switch.
    Red One #3**
    Epic-W
    Digital FX Greg M's Avatar
    Louisiana
    Quote Originally Posted by Matt Hall View Post
    I would rather have the pogo pass through on top. People who prefer cableless monitors will now require Lemo Adapter B with this top plate, which is fine, but it's not simpler. If this plate is basically a replacement for Lemo Adapter A, then make the plate reach over the media bay and convert that Pogo connection to a Lemo for an additional monitor.
    IMO this plate is not designed for you. This is for those of us who use the Pro LCDs with lemo only. Personally I dont like the hinged mounts with pogos, they are limiting and awkward. We always mount our monitors on arms, so this plate is perfect for that type of configuration. My guess is that RED will introduce a separate plate for the hinged monitors. A top plate trying to do both is just too much imo.
    www.digitalfx.tv
    Twitter
    Instagram
    RED One #83
    RED CF Monstro 8K VV
    RED CF Weapon 8K S35 Helium
    Senior Member Tommaso Alvisi's Avatar
    Jan 2009
    ITALY
    Finally!
    Very well laid out too!
    Brent, is the angle of the EVF port fixed or can we rotate it to our desired angle (even if in xx° increments would be great)?
    TOMMASO ALVISI | tommasoalvisi.com
    Weapon MG #0523 aka qp
    instagram | twitter
    Louisiana
    Build quality has defiantly gone up a notch...received a top plate and Canon VV mount today and they are both very well done. The top plate is a heavy beast though.
    www.digitalfx.tv
    Twitter
    Instagram
    RED One #83
    Senior Member Andrew R Lewis's Avatar
    Mar 2015
    Denton, TX (Just North of Dallas Texas)
    Quote Originally Posted by Greg M View Post
    Does the Lemo adapter A fit on the operator side while the top plate is attached?
    Louisiana
    Quote Originally Posted by Andrew R Lewis View Post
    yes, photo attached.
    www.digitalfx.tv
    Twitter
    Instagram
    RED One #83
  9.   This is the last RED TEAM post in this thread.   #29
    RED TEAM Alan Zarnegar's Avatar
    Oct 2009
    RED HQ | Irvine, CA
    Yes, we designed the left rear 3/8-16 mounting point so that there would be clearance for a LEMO Adaptor A on the operator side of the camera.
    /Alan
    Senior Member Fergus Cahill's Avatar
    Sep 2015
    New Zealand
    Anyone know if this has wooden camera master top handle compatibility?
