Thread: V -Lock Stupid Question
Results 1 to 3 of 3
  1. #1 V -Lock Stupid Question
    Junior Member
    Sep 2017
    Hey guys,
    I have a somewhat silly question. Is it possible to power the Raven (or any other dsmc 2 camera) with ONLY the V-Lock adapter, or do you need the I/O plate with it? Just curious to see how much of a "budget" set up I can find to power a Raven. The V-lock plate alone is only 500ish dollars and the I/O plate is obviously much more, so it might something I will add later as funds come in, but can I at least get the camera running with just the V-lock plate?
    Thanks for the advice.
    Yes, you can use a battery module directly attached to the camera, I work this way often when shooting plates.
    In your case I would use the RED DSMC2 Pro V-Lock Module so you can plug the A/C Adapter in when needed.
    You can just run with a simple battery mount adapter too.
    Do note if you don't have something like the Base I/O Expander you can't connect audio or timecode or have HD-SDI or HDMI out. Some sort of I/O is strongly recommended IMO.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Junior Member
    Sep 2017
    Thanks Phil! I will totally get the I/O plate eventually.
