Click here to go to the first RED TEAM post in this thread.   Thread: Non touch LCD monitor and EPIC-W camera configuration
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1 Non touch LCD monitor and EPIC-W camera configuration
    Senior Member Manoj R C's Avatar
    Aug 2012
    Charlotte,NC
    Dear All,
    Both of my RED LCD monitors ( Touch version ) have gone bad and it is being repaired. In the mean time I'm planning to use a smallHD or non touch RED LCD. In this case, how do we change the camera ( EPIC-W) settings? Any help will be highly appreciated..
    Regards,
    Manoj
    Senior Member Scott Evans's Avatar
    Mar 2016
    Wilmington, NC
    I would say just get fool control and control it from there
    EPIC-W #412
    Senior Member Donald MJ Anderson's Avatar
    Aug 2014
    Ontario, Canada
    Is your wifi turned on in the camera settings before you shipped your monitors away? I dont know of any way to activate the wifi without another control source so I leave the camera wifi on just in case my touch monitor dies.
    If its not on you`ll need to borrow a touch and then you can use foolcontrol.
    Red One #3**
    Epic-W
    There is no way to use the Red DSMC2 Side Handle and have the selections and menus show up on an external monitor on the overlay?
    Member Shawn P's Avatar
    Jan 2017
    Toronto, Canada
    I just use my sidewinder. Works great!
    RED EPIC-W #3508
    http://www.red.com/store/products/ds...camera-control
    these work great. Even has slick controls for curves
    Sep 2015
    "Is your wifi turned on in the camera settings before you shipped your monitors away? I dont know of any way to activate the wifi without another control source so I leave the camera wifi on just in case my touch monitor dies.
    If its not on you`ll need to borrow a touch and then you can use foolcontrol."
    Least dependable method. Even if Wifi is turned on FC could just plain never find your camera. Even if it has connected before.
    Aug 2014
    Ontario, Canada
    Quote Originally Posted by Matt Bai View Post
    I hear you. My reliable wifi signal distance is about 3 foot. Better than your zero foot I guess.
    Fool Control is the cheapest method assuming the OP has no other need for a sidekick.
    Red One #3**
    Epic-W
    Sep 2015
    Quote Originally Posted by Donald MJ Anderson View Post
    I set my new iPhone on top of the camera itself. On the fans, to a camera it has connected to in the past. Doing all normal troubleshoot ideas nothing would connect or happen. To say it is not a dependable method is even laughable. You will have a better chance using a can of beans, dont dare try that on a shoot. Or do. But expect the worst, which is absolutely to be expected, with FC on a dependability level. Which is expect to go home early.
    Sep 2015
    No it is not the cheapest method, it is $200 down the drain. BETTER to buy ANYTHING hard wired. REDMOTE???
