Thread: Importing Luts on the camera
Results 1 to 2 of 2
  1. #1 Importing Luts on the camera
    Junior Member
    May 2016
    Could someone give me steps on how to import luts on the camera?
    Are you talking RED Epic? Only DSMC2 cameras support LUTs in camera.
    If you do happen to own a DSMC2 that does support 3D LUTs, make sure you check which LUT precision it supports (i.e. 33x33x33 or 17x17x17).
    If you're LUT isn't to spec, convert it down. If it is to spec all you have to do is copy it to a folder called /luts at the root director of your RED Media Card. You can import it from there.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
