Thread: 512gb Mini Mag not recording after upgrading to Firmware v7.0.0
Results 1 to 6 of 6
  1. #1 512gb Mini Mag not recording after upgrading to Firmware v7.0.0
    I have just upgraded the firmware to v 7.0.0 and the ssd I did it with (512gb mini mag) now is not supported by the camera. The compression rates only go as low as 60:1 and it says R3D recording not supporting when I try to record.
    I tried the other card I have which is a 120gb and that works fine.
    Anyone else had this issue, or any idea's on how to fix it?
    Have you done a "Secure Format"?
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Yep. Have done a secure format.
    Downgraded to 6.3.105 from v7.0.0
    It worked for 2 minutes, then stopped working again.
    It says when I insert the card, this card isn't compatible with this firmware version. The compression rate is limited to a minimum of 60:1 and when I press record it states. R3D recording isn't supported with this card.
    If I put in another card, the 120gb I have. It works fine. Can record, compression rate goes down. Everything is fine.
    Junior Member
    Jan 2013
    Argentina
    I have the same problem with 512gb mini mag, Andrew did you find a solution?
    Apr 2014
    NW Washington
    Do you have any third-party accessories? Tell us a little about your setup. Haven't had any issues with a W and 512G with 7.0...
    Junior Member
    Jan 2013
    Argentina
    Thanks Kevin, I already fix it, I downgrade to 6.3.105 and now Its working fine
Tags for this Thread
View Tag Cloud
