Thread: No_Digimag / Internal_Fault / HDMI Out /
Results 1 to 4 of 4
  1. #1 No_Digimag / Internal_Fault / HDMI Out /
    Junior Member
    Aug 2017
    Miami, FL
    I have a RED ONE MX and am experiencing a few issues:
    My 16GB CF card / 320GB RED Drive attached to the cam and it's saying "No_Digimag"
    When I try to format, I receive "Internal_Fault" same thing happens when I hit the record button.
    Also, I'm not seeing an image through HDMI out. I saw way back people mentioned you need a 35-foot wire for it to work.. Can anyone advise what HDMI's there using that work?
    Thank you.
    Will
    Money spent < Film earned
    Jun 2013
    Kansas City
    I had an AC that recently used a HDMI based monitor on my camera package. I don't specifically what brand it was, but I can assure you that the cable was less than 35ft. I'm guessing it was about a foot long.
    Hope this helps.
    Marcus
    Marcus Guider
    Cinematographer, Camera Operator
    RED Epic Dragon Package
    Contax Zeiss Standard Speeds MMJ
    Junior Member
    Dec 2015
    AZ
    Hey Will,
    Do you get this issue when using the CF card and the Drive independent of each other? What brand HDMI monitor? The R1 is pretty picky with monitors. I never had any luck whatsoever with Lilliput monitors whatsoever.
    Feb 2011
    Atlanta, GA
    I used a Small HD with mine. Sometimes it would take a couple times unplugging it and plugging it back in to get the HDMI to work. The HDMI port isn't the greatest. If you plan on keeping the camera for awhile, a Red or SDI monitor might be a worthwhile investment.
    Jimmy Gilmore
    Writer/Director
    https://Fluid-Films.com
Tags for this Thread
View Tag Cloud
