Click here to go to the first RED TEAM post in this thread.   Thread: DSMC2 Release Candidate v7.0.0rc3
Page 6 of 6 FirstFirst ... 23456
Results 51 to 55 of 55
  1. #51
    Moderator Evin Grant's Avatar
    SoCal
    Quote Originally Posted by Jason Johnson View Post
    I did not have voltage on my AB Wooden Camera plate with the most recent firmware updates so I contacted Wooden Camera. They sent me a new module board and now I have info again.
    On which build? I just had Wooden replace my board but still no info, they say it needs to be enabled in firmware.
    "All art is deception."
    My DP reel...
    http://www.evingrantdp.com
    360 Cinematography and camera rigs...
    http://www.360dop.com
    Member Adolfo CV's Avatar
    Nov 2012
    Portland, OR
    Quote Originally Posted by Evin Grant View Post
    Also curious about this. I still don't get battery info with the WC plate.
    Apr 2016
    Bushkill, PA
    on the latest build, unable to change the compression ratio using the SDI output. I'm using a smallHD 702 but in order to change the compression ratio I need to switch back to the Sidekick using mode button in order to change the compression on there.
    Quote Originally Posted by Mark A. Moritz View Post
    You cannot control the camera through the SDI Output. You need either one of RED's LCD/EVF displays or an interface controller such as the the Sidekick, Sidehandle, or wirelessly via FoolControl.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Apr 2016
    Bushkill, PA
    Not about controlling it through the SDI output. Still working the functions through the sidekick but with the menus displayed on the smallhd monitor. In other words, hitting the mode button on the sidekick allows you to see all menu controls on the smallhd. Then you still have to use the sidekick to control the functions but you see everything you're doing on the monitor itself. It's been working that way without a problem up to the latest firmware. Now, I can still do all those same controls, except for the compression ratio. That one feature you have to switch back and actually view it on the sidekick to change which is a pain when you have the EW on a Movi in the ring on a ReadyRig
    Dec 2012
    New Jersey
    Fool Control works wonders when I have my EW on the Ready Rig. I'd use that solution while you wait for the firmware to be fixed.
