Thread: How to reconnect in camera prores to R3D in Fcpx
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Dec 2013
    Tel Aviv/London
    Quote Originally Posted by BrendanLeahy View Post
    Even easier (as I learned from reduser):
    1.) Create a new folder on your drive or desktop, naming it something like "_____ ProRes"
    2.) Search the folder or drive where all of the footage you want to edit is for files ending in /containing .mov
    3.) Select all of those files once they list out
    4.) Drag said files into the "_____ ProRes"
    5.) Breathe a sigh of relief.
    When you want to reconnect them later to your R3Ds, just direct the reconnect to the original folders and you'll be set :)
    Great explanation, thank you.
    Just one little question: each .mov file is in a separate folder with each r3d file, how do you search for all those .mov inside the main/top folder?
    I wish someone did a quick video tutorial...:-)
    Oron Cohen
    Scarlet-W
    www.oroncohen.com
    Aug 2017
    CA
    Quote Originally Posted by Oron Cohen View Post
    Depends on which version of MacOS you have but generally when you do a search in Finder you have the option to search the entire Macintosh HD or the specific folder you are currently in. The option is below the Toolbar and only appears after you have done a search. I'm not on my Mac otherwise I'd show you a screenshot.
    Dec 2013
    Tel Aviv/London
    Quote Originally Posted by Alex.E View Post
    Thanks, I'll check that!
    I wonder if there is a way to import all the folders as is, put the prores files into a separate event, edit, and then when doing online direct fcpx to the footage from the event with the r3d files?
    Oron Cohen
    Scarlet-W
    www.oroncohen.com
    Aug 2017
    CA
    To my knowledge there isn't a way to link them like you have in Premiere. FCPX really wants you to generate proxies within the application. Works great for short pieces, not necessarily for longer ones though...
    Dec 2013
    Tel Aviv/London
    Thanks for the info. I still wish RED make a new video about the workflow.
    Oron Cohen
    Scarlet-W
    www.oroncohen.com
    Senior Member William Long's Avatar
    Dec 2008
    Sweden & France
    Yes I agree with Oron.
    It would be good to have clear instructions for in-camera Pro-Res working through FCPX that then relink to R3D.
    Mar 2011
    Toronto, ON Canada
    My guess is that the next version of FCPX is going to address a this.
    ___________________________
    10 frame handles
    Vimeo
    Instagram
