Click here to go to the first RED TEAM post in this thread.   Thread: Grain and noise in stills
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1 Grain and noise in stills
    Hi Everyone,
    I'm relatively new to the RED platform. I recently purchased a RED to shoot still and motion campaigns for internal clients who require both and are on a tight budget. I've shot two of these so far and have been very happy with the motion but less so with the stills. I'm getting grainy images that are also a bit noisy when zoomed in to 100%. I'm convinced it's something I'm doing in post but have yet to solve the problem. I usually shoot stills on a 5D MKIII and I'm used to seeing sharp, crisp images when zoomed in to 100%. This is important because I am shooting these wider frames with the intention of allowing the client to crop as needed for print ads and such.
    I'm treating stills and motion separately. Shooting takes for each with setting that are appropriate for each medium (at least I think they are). I'd really appreciate any advice on best practices for this kind of shoot and how to solve this particular issue. I've got another one coming up in a few weeks.
    Gear and settings for still takes:
    RED Weapon Helium
    Fujinon Premier 18 -85mm @ F4
    12fps, 1/400 second, 1280 ISO, 3:1 compression
    REDcolor4/REDgamma4
    Link to TIFF:
    https://ferguson.box.com/s/xc0t8yir6...ud6yq9venhnok9
    Senior Member Shaeden Gallegos's Avatar
    Mar 2014
    LA
    Hey Joshua,
    I would mess a little bit with the 'Sharpness, Denoise, and Detail' sliders in REDCINE-X PRO under the "Look : Image" dropdown/tab. What you are used to with your 5D MKIII, is probably internal sharpening and maybe some de-noising. RED doesn't apply any of these post effects to the R3D clip, so it would be best to mess with some of these settings. Great shot by the way! I would also wait for some answers from people who are more knowledgeable than me in this area ;) Hope you find an answer!
    You don't have to see something to believe in it, but you have to believe in something to see it.
  3.   Click here to go to the next RED TEAM post in this thread.
  #3
    Yes, that's basically it. On the RED there's no NR or sharpening by default. Also, try the IPP2 Beta of REDCine-X which utilizes a new demosaic that extracts more details from the image. Try the DEB setting on the demosaic which will remove the chroma noise that's distracting you, and you can add some USM sharpening too. Or just stick a TIFF out into Lightroom or whatever and do a tiny bit of chroma NR and some sharpening and you'll be happy with the end result.
    Graeme
    www.red.com - 8k Digital Cinema Camera
    Science enables stories. Stories drive science
    IPP2, Image Processing, Colour Science and Demosaic Algorithms
    Senior Member Brendan H. Banks's Avatar
    Jun 2009
    NYC
    I'd put in the STH OLPF and drop your ISO to around 500/640 if you can. I think you'll see a really awesome change there. You won't really lose much in your highlights that way and you'll end up with a far cleaner image.
    Brendan H. Banks
    DP
    Epic-W Helium #796
    Thanks everyone for the feedback.
    Shaeden,
    Thanks for the compliment. I'll try what you suggest.
    Graeme,
    I tried downloading the Mac version of the REDCine-X Beta with IPP2 from red.com without success. I think the link is broken. In general, that's exactly what I did with this file. Exported out of REDCine X and brought the TIFF into Lightroom. Added a little noise reduction in both chroma and luma, added some sharpness, etc. This made the problem worse. Started to look like a Seurat painting when zoomed in. I'm thinking adding sharpness and NR to the RAW file will give better results.
    Brendan,
    I used the skin tone OLPF. I'll try the standard on the next shoot and order bigger lights to get the ISO down.
  6.   Click here to go to the next RED TEAM post in this thread.
  #6
    I've asked for the broken link to be fixed. Thanks for spotting that Joshua!
    Graeme
    No worries...thanks for getting it repaired.
  #8
    The DEB control will work a lot better than the Lightroom chroma NR which basically just blurs the chroma. Similarly their luma NR produces an oil-paint effect. Most of what you're seeing is chroma noise, so try the DEB first and see how you get on. The sharpening should be very similar in both environments.
    Graeme
    Senior Member Aaron Lochert's Avatar
    Oct 2013
    Tucson, AZ
    Quote Originally Posted by Graeme Nattress View Post
    Graeme
    While we're on this topic, will there ever be such thing as "HEB" for Helium sensors? Or is DEB just as suitable?
  10.   Click here to go to the next RED TEAM post in this thread.
  #10
    DEB works fine for now.
    Graeme
