Thread: REDMAG SSD Problem
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 REDMAG SSD Problem
    Junior Member
    Sep 2016
    Hello,
    I'm from Hong Kong. I have a EPIC-DRAGON DSMC Camera and few pieces of REDMAG SSD (64GB, 128GB and 256GB).
    I have been encountering a problem on my SSDs. Some of my 64GB and 128GB REDMAGs were having the same error during shooting with my EPIC-DRAGON in 6K 5:1 format.
    I have tried "Secure Format" for those SSDs with error using the camera, and I have performed "Zero-Pass Erase" with Disk Utility on my Mac. But both methods did not solve the problem.
    May I ask how could I fix the problem? Are my methods correct?
    Thank you very much!
    Can you describe more about the problem?
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Junior Member
    Sep 2016
    Hi Phil,
    Let me check back with the screen capture with error code.
    Thanks.
    Junior Member
    Sep 2016
    Hi All,
    The two photos below are the error code that I am encountering during shooting.
    My Camera: RED EPIC-DRAGON (Firmware: 6.3.102)
    Error Code: 0x000000a9
    "Audio Buffer Overflow"
    https://drive.google.com/file/d/0B6fxlN40spiIQkQ3WGVkbGVlZEE/view?usp=sharing
    Error Code: 0x00000020
    "Please save log and send to RED support"
    https://drive.google.com/file/d/0B6fxlN40spiIdmZuRlJWTW4tVms/view?usp=sharing
    Are these the problems of the camera itself? or problems of SSD?
    Please HELP!!!!! Thanks.
    Junior Member
    Sep 2016
    Anyone could help? Please!!!
    Save the log and send to RED.
    Kirby
    www.kirbyhamilton.com
    Florida
    Nov 2011
    Kelvington, SK
    ive had this problem show up less when i shoot with more compression, try 6:1 or even higher
    Junior Member
    Sep 2016
    Thanks for the suggestion.
    I would like to learn more about if these are the problem of the camera itself? or it's a depreciation of the SSDs?
    Nov 2011
    Kelvington, SK
    i believe it can be either..... in my case it was fixed after a camera repair
    Junior Member
    Aug 2017
    I had the 'audio buffer overflow' a couple of weeks ago with the Red Pro I/O Audio module on a hired in camera. It turns out that the cards we were using weren't fast enough (we wanted to use our own rather than the ones that came with the hired in kit) - We changed to the faster cards that came with the hired in camera and we no longer had the problem.
Tags for this Thread
View Tag Cloud
