Thread: Do RED cameras compress input audio
Results 1 to 8 of 8
  1. #1 Do RED cameras compress input audio
    Senior Member Linda Barzini's Avatar
    Dec 2009
    Chicago
    A sound guy told me that frequently cameras compress audio so it is better to match time code in post. Is this true for RED cameras? For example, if audio from lavs or an F4 went through an A-box, would it be lower quality than just out of an F4?
    Nope. RED DSMC2 cameras record up to four stereo channels of uncompressed 24-bit, 48KHz audio.
    Dedicated audio recorders can do more than that for instance, like 96KHz recording. But to answer the question, uncompressed.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Dec 2014
    Sarajevo
    Quote Originally Posted by Linda Barzini View Post
    F4s got (switchable) limiters built in. So yes, they (can) compress. Severely.
    Advanced onboard limiters provide overload protection which lets you capture audio in a wide range of dynamic sound environments. Limiting can be applied to all four channels simultaneously at full resolution, with 10 dB of headroom and controls for setting threshold, attack, and release.
    New York, NY
    I wouldn't worry about audio formats as most semi-pro and pro cameras record uncompressed 48khz 16b audio... my understanding is that the main difference in sound quality between internal camera recording vs a dedicated sound recording device is usually pre-amp noise... I think the internal camera audio is usually noisier and more susceptible to interference partly due to the extremely high density of electronic parts that introduce electrical interference to the cameras analog audio inputs. The digital recording format specs and compression is just the very last piece of the chain, so there are plenty of other places for the signal to be degraded by your mixing and recording device even if comparing identical digital storage formats.
    Noah Yuan-Vogel | noahyv.com
    Senior Member Steve DiMaggio's Avatar
    Feb 2016
    I use a dpa mic, to lectorsonic wireless directly into my Epic-W. Sounds great, put a good signal into and your fine, just like your lenses, crap in crap out
    steve
    RED TEAM Stacey Spears's Avatar
    Sep 2007
    Sammamish, WA
    I guess you should qualify what you mean by compress. Dynamic range compression or file size compression. Two entirely different forms of compression. :)
    e.g. Phil is talking about file size compression while Šabović Adis is talking about dynamic range compression, at least it looks like it based on the limiters comment.
    Senior Member Paul Russell's Avatar
    Sep 2011
    Malaysia and Singapore
    Red's Limiters aren't very good. Better to leave a bit more headroom.
    Dec 2014
    Sarajevo
    Quote Originally Posted by Stacey Spears View Post
    I can explain:
    Linda said "sound guy", so, naturally, it's about DR.
