Click here to go to the first RED TEAM post in this thread.   Thread: DSMC Release Build v6.3.102
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Senior Member Brendan_H_Banks's Avatar
    Jun 2009
    NYC
    Quote Originally Posted by Andrei Goaga View Post
    Is this ISO recalibration for Helium present in this release build? - http://s3.amazonaws.com/red_3/downlo...r%20HELIUM.pdf
    With this firmware we should use ISO 800 or 1600 with Helium?
    Very interested in this as well.
    Brendan H. Banks
    DP
    Epic-W #796
    Voltage is back with my WC cable-less battery plate again!
    Thanks!
    EDIT: I dont see the option for varispeed audio recording anymore under Menu>Settings>Recording>Mode anymore, was it relocated?
    Senior Member Manuel Wenger's Avatar
    May 2007
    Hohenkammer, Germany (near Munich)
    Is IPP2 fully integrated in this built, or is 6.4.21 still the way to go for that purpose ?
    MR International Director & DOP Team
    Epic-W - Motion Control Equipment - BeSteadyFour Beast
    based in Munich - working everywhere
    AGENCY: Dirs-n-Dops Berlin
    Feb 2016
    Los Angeles, CA
    Quote Originally Posted by Manuel Wenger View Post
    Definitely 6.4 for that. IPP2 is not in this build.
    Jun 2008
    Germany
    Audio buffer error at 8KHD 50fps. Base i/o and Mini-jack cable. Freezes the camera and need to reboot the cam. Cam also went up to 80degrees and switched off. After 30 minutes cooling down and switching to manual fan control, I just got the audio buffer errors. BUT the 18-35 worked again :)
    Edit: may you re-activate phantom power PLZZZZZ
    Weapon Carbon #1119, Epic-X #7926 BAM, Raven #220
    May 2011
    Las Vegas
    Does this release have the SW 4K ProRes?
    BC
    Director/Editor
    www.brandon-christensen.com
    Scarlet-W - 000071
    Member Azzie Scott's Avatar
    May 2013
    New York City
    I already called and let the RED tech team know, but after the update to v6.3.102 I lost touch capabilities on my 4.7 inch using the Lemo A and Lemo B adapters with the LCD2 port on the side of my brain. So I had to roll back to V6.3.101 and everything worked again. Im sure they will fix this in the next update. RED has done a great job quickly squashing any pesky bugs.
    WEAPON HELIUM "Stealth" #04505
    MOVI PRO
    Dream Dept. Media Inc.
    http://www.thedreamdept.com
    Dreams. Illustrated.
    Sep 2009
    Hamburg, Germany
    Quote Originally Posted by Azzie Scott View Post
    I just had to roll back to FW 6.3.101 as well since the RedLink Bridge caused the camera to shutdown improperly on 6.3.102.
    I hope this will be adressed as well in the next update . . .
    THX !
    Regards,
    Marcus
    EPIC DRAGON rental and green screen studio: CINE-VFX.com /STUDIO11-Hamburg.com
    Senior Member Audy Erel's Avatar
    Nov 2016
    Jakarta-Bandung, Indonesia (Bali)
    Yep.. I can't use the touchscreen on the side port as well. Waiting for the awesome Release build 7.0 !
    SCARLET-W #004760
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    I'm constantly loosing my monitor HDSDI preset after each reboot. Is it due to the firmware?
    25p 1080 resets to 60p 720 clean
