Thread: Audio mixers at editing stations
Results 1 to 10 of 10
  1. #1 Audio mixers at editing stations
    Senior Member Linda Barzini's Avatar
    Dec 2009
    Chicago
    I remember seeing audio mixers at each editing station at some post production facilities. What were they used for? Isn't audio generally delivered by CF, SD, or other digital delivery?
    Senior Member Andrew Gentle's Avatar
    Jul 2008
    Brisbane, Australia
    Hi Linda, after the audio is delivered it still needs mixing. These days, those audio consoles are likely to be control surfaces which can control the software which actually performs the mix, so that the operator can work in a more quick and hands-on way.
    Scarlet-X DRAGON #64
    Nov 2011
    Brooklyn
    Most editors don't use those boards anymore - except for recording scratch tracks, etc, and for riding levels on the main monitor speakers.
    Nick Morrison
    Founder, Director & Lead Creative
    // SMALL GIANT //
    smallgiant.tv
    Senior Member Steve Sherrick's Avatar
    Boston
    If you are talking about an outboard mixer like a small Mackie, these are useful when you have multiple sources of audio you need to monitor through your main speakers. For example, we could listen to the sound coming off a tape deck, or a mic hooked up for doing temp voiceover, etc. And of course monitor the sound coming from the NLE. Just gives you a lot of flexibility for monitoring. At the very least, you want a way to control volume and mute sound altogether. Very dangerous otherwise because you want instant control if a track slams in really hot and you need to turn it down for a moment.
    A control surface that interacts with the NLE is used for setting volume automation and many find a more organic way to mix tracks as opposed to drawing volume automation.
    Steve Sherrick
    Senior Member Kwan Khan's Avatar
    Jan 2008
    NYC
    Quote Originally Posted by Nick Morrison View Post
    Agreed, sitting following on my side table for over decade (was sent by Euphonix - Beta Test), uses on rare occasions (lol), but it's a good Panel
    http://www.avid.com/products/artist-control
    No, I do not RENT MY GEARS... - NYC (Times Square)
    EPIC-D with 9" touch, 4 RAVENs, RPP, Sigma 18-35 PL, Motion Mount, VF/RED-rock wireless FF, Pana 17", JVC 20", Seadicam with SEGWAY, Letus 4-Axis with L'Aigle Exoskeleton.
    Trash-Can 12-core Max'd-out) +MBP (Retina), RED Rocket (Sonnet), RAID system (Promise Pegasus II), Adobe Production (CC), FCS2, Resolve 12 with MC Color, 50" 4K Panel
    Senior Member Ben Scott's Avatar
    Mar 2011
    London, UK
    I used to manage Avid facilities in the late 90s and then worked at ITV's post facilities. Even then the mixers were purely for monitoring purposes in all our suites.
    2018 Reel
    Instagram
    Dec 2009
    Hollywood, USA
    Quote Originally Posted by Ben Scott View Post
    Yes, this is still done in traditional Avid stations in LA today.
    marc wielage, csi colorist/post consultant daVinci Resolve Certified Trainer
    Jan 2008
    Auckland, New Zealand
    Monitoring and or automation for temp mixes.
    If I had the choice I'd use a control surface type mixer as a way to control levels in the temp mix everytime, way faster generally to do a pass with the sliders than mess about with levels on each clip.
    Dec 2009
    Hollywood, USA
    The standard mixer I generally see at most Avid or Premiere editing workstations is the Mackie 1402:
    It's small, cheap (well under $400) and is very simple and easy to operate. I think I've been seeing these in digital edit bays for more than 15 years.
    Those who say they think they'd rather use the on-screen controls don't take into account three things: 1) a physical mixer has better response, at least in making very subtle changes; 2) a mixer like this is extremely cheap; 3) it runs no operating system, needs no updates, and just sits there and works. It's kind of like a hammer: it's designed to do one thing and does it pretty well.
    Bear in mind these are not used for the final mix: it's really just for monitoring and temp mixes.
    Dec 2008
    I use a mixer for monitoring.
    The computer has audio output, and so does the capture card (blackmagic). You also have headphones, and speakers (that might or might not be at reach for the headphones cord).
    So I use a small mixer, so that I can push the fader up/down of the capture card or the internal sound card of the computer without having to mess with settings in the OS. I can kill the master output, and use only headphones if I want to edit with headphones.
    I would not go for a mixer like the Mackie though. Just because it eats too much desk space. Depending on your needs, something as small as a Behringer Xenyx 802 could do the work (I use a similar but older model), and make your life easier, and those go for about fifty bucks.
