Thread: Epic-W 4k ProRes 422 HQ Proxies Split into Multiple Clips
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11 Found the source of the problem
    Junior Member
    Apr 2013
    Found the solution, but has to be done in-camera. When you format the REDmags, you have to change it from FAT32 to UDF.
    Junior Member
    Aug 2017
    Kansas City, MO
    Quote Originally Posted by Kevin Reilly View Post
    I'm trying to edit with ProRes 422 proxies and sync audio but all of the clips are split up when I import into Premiere CC. Because of this I can't synch my audio.
    I'm aware that red divides long clips into 4gb segments, but no matter how I try and import I can't get them to ingest as a single clip.
    Is anyone else experiencing this problem?
    For future reference, format your mini mags in the UDF format instead of FAT 32. This feature was added around firmware 7.0 I think and Iíve been using it for Prores and Raw recordings for 2 years without problems. It removes the 4gb file size limit of FAT 32 so that you can have just the one single Prores file for as long as you have space to record. Also, I highly suggest always doing secure format for that extra sense of reliability. Good luck on the current project!
    Jul 2013
    Atlanta, Ga
    Quote Originally Posted by Tyler Zak View Post
    Yep. U can record both Raw & Pro Res for assurance. Just make sure u have the card space or shoot at high compression ( that is comfortable) if you donít.
    Last edited by Brandon Obey; 03-08-2019 at 08:34 AM. Reason: Forum doesnít accept emojis
    Cinematographer - Camera Operator
    Portfolio:www.vimeo.com/brandonobey
    Senior Member AndreasOberg's Avatar
    Oct 2011
    Does it also work with UDF for Red Raw?
    www.ObergWildlife.com- Natural History Filmmaking
    www.WildlifeRescueMovie.com- Saving the animals of the Rainforest!
    2 x RED DSCM2 8K Helium Movi Pro Gimbal, Inspire 2 X7, OConnor 2560, Canon 50-1000mm
