Thread: Epic-W SDI issues
Results 1 to 9 of 9
  1. #1 Epic-W SDI issues
    Senior Member Domenic Barbero's Avatar
    Nov 2011
    Seattle/Portland/LA
    Was on a shoot today with my Epic-w and was noticing that when I powered down the camera, if I turned it back on with the bnc connected, it wouldnt send an image out to monitor. I had to turn camera off, unplug, power up, then replug in. Anyone else having that issue? I should also state this was out of the vlock I/O module
    DP/Director/Producer
    www.domenicthedp.com
    www.nw-camera.com
    Alexa Mini/Amira, RED Dragon, Monstro, Canon C500 Mark ii, C300ii, Sony FX9, FS7, UMP G2, Pocket 6k/4k, Sony A7s/r ii, Cooke Panchro Classics, Atlas Anamorphics, Zeiss Cp3, Angenieux EZ1/2, Celere HS set, Leica R Duclos set, DSO Trump series, Sigma Cine Primes, Contax Zeiss Superspeeds, GL Optics 18-35, 50-100, 70-200, tokina 11-16 PL, Laowa 24mm Probe, Movi Pro, Grip Vans, Skypanels, HMI's, Hive, Aputure, Litepanels, Litemats
    Had the same issue running out to a Teradek Bolt, everytime camera was powered down I'd have to remember to turn the Bolt off before I powered down and unplug SDI before powering up again. Eventually found a simpler solution:
    Go into the monitor settings, select HDSDI, turn it off and on, seems to reboot the SDI out.
    Nov 2011
    Seattle/Portland/LA
    that is a bit easier of a fix. Ill have to try that one. Hopefully it gets addressed in a firmware
    www.nw-camera.com
    Senior Member Aaron Lochert's Avatar
    Oct 2013
    Tucson, AZ
    Just wrapped a shoot this weekend and was experiencing the same issue with a Teradek Bolt and SmallHD 502. Somewhat relieved to see that it seems to be a firmware bug and not an issue with the port.
    Oct 2015
    Madrid, Spain
    The same problem going straight to a monitor and with a IDX Camwave
    Seems to be firmware
    Dec 2016
    Los Angeles, CA
    I had that same issue on the shoot with the first IPP2 beta firmware and went to the menu to re-init the SDI port. I upgraded to the latest IPP2 beta and it seems like the issue has been resolved.
    Same here, and actually have a support ticket out for it. Strangely, another way to get it back to life is to simply open Foolcontrol on the nearest iDevice. Once it connects to the camera (you get the main interface on the screen) the SDI port magically comes back to life.
    Carlino // wearecarlino.com
    I dangle things with lenses out of things with tail rotors.
    Epic-W #004102
    Arriflex 35-III 3-perf
    Jul 2011
    Norway
    Ive had this issue With both my Raven and Epic-W, but With the HDMI Connector. I was using a Paralinx Arrow+, and I always have to unplug and replug the HDMI after turning the camera off
    Member Jordan Beard's Avatar
    Sep 2016
    Boston
    Does anyone know if this issue has been fixed in recent firmware updates? I've noticed a similar problem with my Scarlet-W recently.
    Jordan Beard
    Canopy Films
