Thread: FCPX and 8K Helium
Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 68
  1. #1 FCPX and 8K Helium
    Senior Member Scot Yount's Avatar
    Dec 2014
    Marblehead, Massachusetts
    For what it is worth, I just downloaded the latest version of FCPX 10.3 and it now imports and plays RED 8K Helium files from my Epic-W. I was able to do this on my stinking old early 2011 MacBook Pro!!!
    Forged CF Helium 8K 00107
    Scarlet X 02249 (The Gateway Drug)
    Fujinon Cabrio 19-90 Version 2
    RED Pro Zooms and Primes
    Director/DP at https://www.butcherbox.com
    Living life by the ocean.
    Senior Member Steve DiMaggio's Avatar
    Feb 2016
    yeah I just posted in another thread, it super fast also
    Steve
    Dec 2010
    Toronto & Vancouver
    Does it FCPX 10.3 allow you to choose the "performance playback" resolution? I'd love to be able to select 1/4, 1/8, etc... with a full res "paused" resolution.
    Feb 2016
    its less complicated than that, you can choose from original/optimized better playback, original/optimized better qualilty, proxy
    I just transcode to proxy right in fcpx and choose proxy, when I am done editing I choose better playback for grading and fine tweaks better quality. Literally takes 2 seconds in the drop down, just like RCX
    Steve
    Senior Member Curtis boggs's Avatar
    Jun 2016
    Virginia Beach, VA
    thanks for the info !!!
    Curtis Boggs
    www.cboggs.com
    Cinematographer-DP-Colorist
    Epic-W 8k - G&E
    Sigma Cinema zoom set
    Leica-R Cine mod prime set
    Senior Member Steve Sherrick's Avatar
    Boston
    Sitting here working on a project in FCPX (10.2.3) and the one thing bugging me about the proxy workflow within FCPX is that it forces you to delete the proxies if you want to go back and tweak the R3D RAW settings. I can't find a good reason for why they are doing that. Obviously anything you tweak won't be reflected in the baked in proxy file, in which case if you need the new look in the proxy then you would re-transcode. But sometimes I want to play with color in RAW and then go back to editing with proxies and don't need to see the color updated at that point. So, this is a bit of a drag. Have they fixed that in 10.3?
    Also, finding that Izotope plugin Rack crashes FCPX quite a bit and also having some crashes related to Color Finale Pro.
    But, I have grown to really like a lot of things about FCPX, and eventually will update the big thread I had going.
    Steve Sherrick
    Feb 2016
    yes you do need to re transcode, which is a pain, I removed all my izo plugs long ago, I forget why
    steve
    Senior Member Terry VerHaar's Avatar
    Sep 2009
    Marin County, CA
    Quote Originally Posted by Scot Yount View Post
    Is there a new RED workflow installer that needs to be installed? Or the old one works?
    (I see that the last date on the RED site is 10/11/16 - which I definitely don't have yet.)
    Also - my App Store app says I have 7 apps needing to be updated but they aren't showing up. Anyone else having this issue?)
    Thanks.
    Scarlet Dragon
    Scarlet-W
    Feb 2016
    Quote Originally Posted by Terry VerHaar View Post
    I only updated FCPX
    Senior Member Andy Roberts's Avatar
    Dec 2008
    Southeast US
    Quote Originally Posted by Steve Sherrick View Post
    As I'm just learning to edit my own stuff, I'm genuinely curious as to the main pro and cons of FCP vs Premiere vs Resolve (if it can be considered a contender). I own both and Resolve is free.
    Do you have 3 bullet points of what you REALLY like about FCPX Steve?
    Andy Roberts
    Nikon and Leica-R lenses (for sale)
