Click here to go to the first RED TEAM post in this thread.   Thread: 1080P Capture Via Build 16
Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 59
  1. #1 1080P Capture Via Build 16
    Senior Member Steve Sherrick's Avatar
    Boston
    I've experimented with capturing the 1080P output of Red Build 16 into FCP via a Kona 3 and have not had any luck. The signal comes in with a greenish/purple solarized effect. Checked it with a direct connection to an HD-SDI monitor as well with same results.
    Anyone else try this? Same experience?
    Also, it would be cool if the audio would travel down the HD-SDI pipe as well. That would offer a pretty cool realtime processing system (even though you have to compromise on the quality a bit). Some jobs it would be perfect for.
    Steve Sherrick
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    I thought 1080 didn't work (corectly) yet with build16 only 720p...
    Pat
    Boston
    Hmmm.. Maybe that's it. I thought it was implemented in beta, but maybe it's not going to be ready until release build. For what it's worth, I tried capturing 720P and ran into problems there as well.
    Steve Sherrick
    Quote Originally Posted by stevesherrick View Post
    Steve - the Kona does not YET support 23.98p (not psf) capture. It is a driver issue - they are working on it.
    Also, you should know that the 1080 output from the RED is CROPPED - so on playback you are not seeing your entire frame -
    Mark L. Pederson | Director of Technology | OFFHOLLYWOOD
    Blog - MegaPixels.io
    http://twitter.com/offhollywood
    Jan 2007
    I've gone straight into a JVC with 1080P playback. It supports true 24P. To me it looks about like 2K Medium Res in RedCine.
  6.   Click here to go to the next RED TEAM post in this thread.
  #6 HD 1080 output
    Red Team Stuart English's Avatar
    Irvine, Ca
    It is cropped and scaled, i.e it is first cropped to 3840 x 2160, then scaled to 1920 x 1080...
    Workflow Wizard
  7.   Click here to go to the next RED TEAM post in this thread.
  #7 1080p formatting
    Irvine, Ca
    Also note that the "HD-SDI" outputs are RGB dual link 4:4:4, so try the PREVIEW output - that is the more common 4:2:2 signal.
    Workflow Wizard
    Boston
    Thanks guys!
    Steve Sherrick
    We also did a test today and were able to record the output on a HD-D5. Please note: not many devices out there like straight 24P, we think the Quantel EQ will be OK with it.
    Boston
    From the preview output correct?
    Steve Sherrick
