So, here's my issue (apologies if I should have put this in the bugs section but it seemed like that was more for gear and it'd be better suited here). As of a couple of builds ago, RCX would occasionally crash and upon playback I wouldnt be able to play a constant clip (it would freeze on one frame no matter what I did).
I updated to the latest version, 40.40706 and have the latest ATI/AMD drivers for my 7970 Ghz Tahiti card - 12.20, OpenGL v 6.14.10, OpenCL 2.0.6.0. Running Windows 10 64 bit fully up to date. I've tried disabling the graphics card in RCX also. (Interestingly enough it says the OpenCL version in RCX is 1.2 and not 2.0.6.0 like in the AMD settings).
Whenever I open the program, it stays open for maybe 30 seconds before it crashes - same for the RED player standalone. Everything works fine in premiere. As soon as I open the program I get a red ! mark in the upper right corner saying
[07-12-02-05-28-946] GL PBO Size ERROR: 1280
[07-12-02-05-28-957] GL Texture Size ERROR: 1280
[07-12-02-05-28-999] GL Texture Size ERROR: 1280
The rest of my log is as follows (not sure if this will help):
[07-12-02-05-29-042] VideoWindow::Pause
[07-12-02-05-29-042] >> TIMELINE::TimeLine_Core::updateMarkersVisibility
[07-12-02-05-29-042] Tried to get markers but clip_ptr is zero
[07-12-02-05-29-060] Finished Browsing for Cameras.
[07-12-02-05-29-060] Timeout or error receiving data on port 1112: The I/O operation has been aborted because of either a thread exit or an application request
[07-12-02-05-29-060] Camera Discovery Service Ending.
[07-12-02-05-29-124] PBO GL Error != 0 on copy to texture. PBO glId: 1 error: 1280
[07-12-02-05-29-124] glBindBuffer GL_PIXEL_UNPACK_BUFFER 0
[07-12-02-05-29-124] glTexSubImage2D GL_TEXTURE_RECTANGLE_ARB, 0, 0, 0, 1 , 1, GL_BGRA, GL_UNSIGNED_INT_8_8_8_8_REV, &badPixel(000000002270F7F0)
[07-12-02-05-29-176] Stereo3dWidget::setClip() - Not a 3d clip
[07-12-02-05-29-185] InstantUpdateStart
[07-12-02-05-29-185] InstantUpdateEnd
[07-12-02-05-29-267] AudioWaveformStream::setup(): Bad clip
[07-12-02-05-29-267] stream can't be setup
[07-12-02-05-33-386] Update Timer Stopped
[07-12-02-05-33-408] XML ERROR on line 1, column 1: Start tag expected.
Tag:
[07-12-02-05-33-509] XML ERROR on line 1, column 1: Start tag expected.
Etc.
Anyways, I've tried reinstalling the RCX, older versions, rolled back my Gpu drivers, reinstalled those, and no matter what I do it won't run properly.
Is this a known issue? Is there a workaround? Let me know, I like to do my first quick color pass and organize in RCX before premiere. Much appreciated.
