Thread: Red Fashion Photography Dead?
Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 53
  1. #21
    Senior Member Christoffer Glans's Avatar
    Jun 2007
    Stockholm, Sweden
    Quote Originally Posted by Ulf Krentz View Post
    Once again, specific tasks call for appropriate tools. I don´t really see your point. I am very picky about catchlights and how eyes are lit, there is no need to grill a model with continuous lighting and regarding heat a professional strobe system is equipped with tungsten modeling lights (in our case 650W each) and won´t run cooler in a small studio. My experience has been completely different, while we cannot use a motion workflow for the majority of our work it feels more organic and it is easier to get authentic expressions than with MF and strobes and we never ever experienced any heat related problems with make-up, materials, too narrow pupils or making the model feel uncomfortable, rather exactly the opposite. That said I use moderate HMI wattages for these kind of jobs like for this one:
    https://www.facebook.com/14493314120...type=3&theater
    Taking a photo like the one you linked to is not very hard with HMIs while reducing things like heat etc. Try doing a 20mm environment full body shoot with five+ light rigs on a location without much power supply. And I think you say the same thing as I do "specific tasks call for appropriate tools". But I didn't come from still photography using the modelling lights on the flashes, I used a light meter. I could have an entirely dark studio and still light my subject with my flashes. I have experienced first hand the result of a shoot with HMIs that turned the models sweet into makeup mess, which wouldn't have happened with flashes.
    As for the eyes, try darkening the studio, use flashes and take some photos of a modell when you've been in the dark a few minutes. It's not about any "problems" with the iris, it's that you can never get that kind of gaze with HMIs, that's just biology.
    Then there's also the f-stop reason. Using flashes you can pretty much take photographs at F8.0 no problem. With HMIs you need a lot of lights for that or push exposure time down or ISO up.
    "Using any digital cinema camera today is like sending your 35mm rolls to a standard lab. -Using a Red is like owning a dark room."
    Red Weapon 6K #00600
    Links
    Epic Dragon & Canon CN-E street test
    Red Epic - Noise Reduction Test - Stockholm 2014
    Red Epic - Stockholm HDRx Test
    Senior Member Ulf Krentz's Avatar
    Jan 2012
    Germany
    Quote Originally Posted by Christoffer Glans View Post
    Christoffer,
    sure, that would be a shot I won´t approach with a motion camera. I think we´re not so far apart. I´m coming from photography background and enjoy the additional possibilities with a motion camera. Bringing out fine textures of fabrics in a full body shot is not exactly where a motion camera shines. Regarding the eyes of a model, I don´t intend to make them look like on drugs, so I usually will have the modeling lights switched on to have the iris closed a bit, the modeling light nearly has no effect to the final exposure as the flash is a hell of more brighter like Zeb already pointed out, no problem to have a bright sunny day look like a night shot and impossible to achieve with continuous lighting.
    @ Zeb, regarding the sizes of HMI and strobe, what are you referring to, do you compare a hotshot shotgun with an Arrimax? I wholeheartedly disagree on this point. Flash tubes are thick and long, at least a couple of inches, are linear circular or wound up, so they cannot be a point source like a HMI with light emitting from a gap between the electrodes of what, half an inch or even less? If I´m in need of a crystal clear shadow I will always consider if it makes sense to use a HMI bulb for that even when using strobes for the rest of the lighting.
    I also disagree on the point of being a cheaper way and "only" for web. Web has been growing to the most important place photos and ads are placed and with the zoom in functions requires even more resolution than print. I also think it is more important to create an authentic content and mood, I know this is a technical forum in the first place but note you won´t sell anything because of high resolution pixel peeping. YMMV.
    Senior Member Zeb B's Avatar
    Sep 2011
    In The Moment
    I take it one step further . . . to the human level. Models and a good photographer develop a rhythm during a shoot where the strobe "ready" beep is the 4/4 beat to. Without that rhythm (hot lights) there is no pulse and no pause to strike a new pose. It's a timing and flow thing between us. There is also the glamor of the flashing lights - like a night club - where he / she is the star on the dance floor or red carpet. Or you can blast the model with all the sexy intimacy of a 10K HMI ;-)
    Just kidding. RED cams are the best at everything.
    -Zeb
    FAA 333 Drone Ace
    6K Drone Worldwide
    Underwater Shooter
    RED in Hawaii w/Operator
    www.Stock8K.com
    Jan 2012
    Germany
    Thanks for sharing your precious insights. There will still be that 1 or 2% of work that I like to use a RED for stills or a combination of stills and motion though.
    Aug 2015
    I believe the future is in pulling frames from video, as the cameras gets better and better.
    Helmut Newton did plenty of fashion photography without much use for flash, and before flash become a standard in fashion photography, due to improved technology.
    In 2002 Hasselblad introduced the H1, which was attached to a 16Mp Kodak back, if I remember correct. Plenty of billboards and print ads created with a camera far inferior to a modern RED (sensor-dynamic range-ISO).
    Standards are changing fast. CD's are way far superior to both vinyl and mp3, as for sound quality, and yet they are now lost in transit.
    Sep 2011
    In The Moment
    Thank you for your condescending reply ;-)
    -Zeb
    FAA 333 Drone Ace
    6K Drone Worldwide
    Underwater Shooter
    www.Stock8K.com
    Jan 2012
    Germany
    Quote Originally Posted by Zeb B View Post
    Ah, come on. No offense. I thought we had a serious discussion here - you were just asking for it with your torn out of context comment "RED is best for everything" :-)
    The rhythm you described can be a valid point when doing commercial stuff but I was referring to the recent style of photography that is less influenced by "posing" of a model and more based on showing authentic, more film like situations / moods in which I could imagine to and have been pulling stills from motion or just lighting with continuous sources. I also used this for personality portraits with great success. This is in no way meant to replace a stills camera (see my first post in this thread) or take over a significant amount of our work. I am just sharing my personal experience as a working photographer and I thought it might be of interest for somebody here.
    Cheers
    Ulf
    Senior Member Josh Wilkinson's Avatar
    Mar 2016
    DFW, TX
    Quote Originally Posted by Alberto Guglielmi View Post
    I think for day to day stuff this is true. There will always be a place for the ultra high end Medium Format/Full Frame stuff.
    I haven't had a legitimate photo shoot in 6 months, I actually sold 90% of my photography equipment when I bought my Scarlet.
    The new waves of LED Fresnels/Pars are going to solve a lot of the Heat/Power issues. (especially in the more budget market)
    The S-mount Par lights that have been coming out are outstanding for hybrid work. No flicker, super cool, can use normal softboxes, and are under $500-$1000
    Aug 2015
    Hey Josh, can you post a link for those S-mount Par? Or the brand. I could not find them via search.
    PS I agree. There are always going to be the need for specialized stuff. But the 100Mp MF cameras hold very little interest for me, and I even barely have requests for MF shoots in general.
    What release was that? Is that the case on Weapon?
    Basics:
    in Film you want motion blur to blend frames so you shutter for that
    In Stills typically you want frozen, zero blur so you shoot with very short duration strobe flash
    Pulling frames from motion is fine for web use but would never reach the level of quality of a MF stills cam + strobe. It's a budget saving compromise for those who don't want to spend for a professional Filmmaker and Stills Photographer.
    From a lighting POV: take a camera that is fixed at say ISO320, then let's say you want both eyes in focus shooting on a 100mm+ lens so you have to shoot at F8+, then you want the action frozen so you're looking at shutter 1/500+. That's a freakin big ass hot light both in watts and physical size to ETTR.
    A strobe the size of a baseball can overpower the sun by a bunch without melting the model. The quality of light from a very small light source can never be matched by that of a very large source. You can always make a small light source bigger - hard to reverse it. The specular quality you get on micro detail like metallic make-up or fabric cannot be matched with hot lights. Size matters.
    As budgets get squeezed I can see RED style cameras being used in a pull frame capacity. That does not mean it is a better method - just cheaper to produce. Like CD's v. Vinyl
    Regarding the shutter speeds... the fashion people we work with do not care much for 180 deg shutter for motion. Even back in the film days we shot most high end fashion films for Hugo boss and others on 50ASA and 45 deg shutter and 100 fps and then none of that was going to print, they just simply wanted the film to look like their prints. So if that was not a problem back then why would it be now.
    The lights vs strobes... Ofcourse it´s easer to use strobes. But in a well ventilated high ceiling studio it´s actually quite nice to work with a constant light setup contra a dark photo studio where the strobes are smacking away every other second for days on end. And with todays light tech I find a lot of still guys actually like it when all is setup correctly. Off course we also tried the opposite...trying to push high frame rate / flicker free lights into some little still photo booth then off course the place is about to catch fire before lunch... But when setup correctly it´s quite comfortable for everyone, makeup etc, not to work in the flashing dark.
    Right now I´m in paris working for possibly the most grand fashion brand of all. They will shoot their stills with still camera but they will do it in the light set of the film. And it´s not about money or any such thing. They got 2 weeks to do it and rented pretty much every camera lens and light you can think of to shoot. So simply they just want the light of the film which is done with a huge rig with 40 or so sky light panels + a bunch of other light. Something that would be would be more than bit cumbersome to replicate with strobes.
    Also I was a bit surprised as the DIT down here had 3 rocket X in his cart, and when I asked why he had three of them he explained that the company he works for has 9 weapons. I asked him why he had so many, Fashion still photography was the answer... And if I understood him correctly they are all about to go in for the 8k upgrade.
    So I for sure think the motion for still approach for fashion is not just a new hat trick or the gimmick of the moment, I think it´s where fashion shoot will go. I even see a not so distant future where most agencies and clients will not tolerate just to get single frame captures from such shoots. When they understand how it all works they will demand that the camera is capturing even before the model goes in front of camera.
    But yes the key is to use the right kind and strong enough light. Joker bug soft tubes are good, Area 51 led fixtures are good.
    Björn Benckert
    +46855524900 www.syndicate.se
    Flame / VFX / Motion capture / Monstro
