Thread: LATITUDE-SIDEKICK MODULE
Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
  1. #1 LATITUDE-SIDEKICK MODULE
    Senior Member Patrick Tresch's Avatar
    Aug 2007
    Switzerland, Lausanne
    Hello,
    Anybody going to NAB 2016 could give us some more infos about the Latitude Sidekick module that mounts between the Weapon body and Red's Sidekick?
    I think their vision is really clever. Closer to the lens is always better!
    I would love to see the prototype working on a video (if it's ready yet).
    Patrick
    Nov 2008
    Dallas, TX
    This is so incredibly BADASS and the most innovative design I've seen. Who knew you could stick stuff BETWEEN the sidekick and the body. Awesome
    JAKE WILGANOWSKI
    Director of Photography / Filmmaker
    CINE-AUTOMATIC.COM
    Nov 2012
    im very curious about it too. does it need to be powered by a cable though or it gets its power from the pogo port, and do you need a sidekick attached?
    and most of all can you mount it btwn the new side grip!!!
    seems like the best thing ive seen just to even have lemo ports.
    Aug 2007
    You have to power it as the power draw : motors & 3 extra Lemo power output, needs more Amp. But I wonder how much power it would eat up with 1 motor, RF and 2 thumb wheels?
    Good question about the side grip.
    Pat
    PS: as this is fine tuned for the Weapon I hope they will make custom calbes and not those 60cm cables they have as standard (power&motors).
    Senior Member Jonathan Stevenson's Avatar
    Nov 2008
    Denver
    From what I read on Facebook, you need a very short power cable to plug it in, the sidekick connector isn't enough to power it. So you run a little 3" cable from the aux power out on the camera to the module, or from the Ptap. You also need to run a very small ctrl cable to it so that it can do start/stop functions and control EF lenses from the hand unit. So, while it's positioned under the sidekick, it appears to only be passing through the sidekick functions and not actually using that connection for anything of it's own- which leads me to assume it'll work with the new side handle as well.
    Which is fine by me, I think it's a brilliant design and will definitely be getting one. Seems like a small enough accessory that it can just live on the camera like a top plate. When you're not using a FIZ system, you just take off the cables and you're good to go. This will be a killer solution for Movi setups too; one more way to make the camera setup more streamlined and simplified.
    Aug 2007
    Also great for rental options. Take it off if no FIZ is needed!
    I'm on the list for preorder!
    Pat
    Senior Member Mikael Lubtchansky's Avatar
    Jul 2007
    France
    Not compatible with new side handle, but can also just have any dumb sideplate (sidekick not required)
    Yes needs external power.
    In an ideal world yes we could eliminate CTRL cable... Kris can certainly do it... But not 100% sure the sidekick connector is available for 3rd parties yet (that is why it was conceived as a pass thru only for now)
    Yes to installing this module and never remove it again ;-)
    thanks Sam Renollet from RVZ for pushing this idea from the beginning and Kris for turning it into a great product.
    Working proto will be at NAB but without sidekick passthru (yet) as it is just 'hot out of the oven'...
    Kris is on the plane right now to NAB with it so he may reply later with more info on this latitude...
    foolcat : HTML / PDF visual reports for OS X
    foolcontrol : RED camera control for OS X
    foolcontrol : RED camera control for iOS
    foolcontrol : RED camera control for Android
    foolcolor.net staying hungry, staying foolish facebook instagram
    Nov 2012
    wish i didnt have to cancel nab for work, dying to see this all work, still a little confused about it all.
    i am for sure looking to get a working lemo prt on the camera somehow, but also a wireless focus system.
    now am i wrong, but this can work with EF lenses with no focus motor too?
    just this, and a handset? and you use a motor only when you have true cine lenses attached?
    Mar 2011
    Toronto, ON Canada
    Anxious to see it in person.
    ___________________________
    10 frame handles
    Vimeo
    Instagram
    Senior Member Chris McKechnie's Avatar
    Mar 2011
    Dallas, TX
    Something is brewing in regards to this...more hopefully soon!
    Chris McKechnie
    Email - redepicguy@gmail.com
    Reel - https://vimeo.com/314919326
