Click here to go to the first RED TEAM post in this thread.   Thread: DSMC2 V-Lock Battery Module
Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
  1.   Click here to go to the next RED TEAM post in this thread.
  #1 DSMC2 V-Lock Battery Module
    $595
    http://www.red.com/store/products/ds...battery-module
    ESTIMATED TO BEGIN SHIPPING IN FALL 2016
    The DSMC2™ V-Lock Battery Module is a low profile cable-free module that enables you to power your DSMC2 BRAIN and camera accessories using RED BRICK and third-party batteries. The V-Lock and protected release button ensure ongoing power even during mobile shoots.
    This DSMC2 battery module also offers a P-Tap connector for powering peripherals and accessories. Located on the top of the module, the P-Tap connector supports a maximum current of 3.0 Amps.
    Manufactured from robust aluminum alloy, this DSMC2 battery module offers a blend of utility and power support in a lightweight and space-saving form factor. The DSMC2 V-Lock Battery Module is an ideal power solution for use with most DSMC2 expanders. Alternatively, connect the DSMC2 V-Lock Battery Module directly to your DSMC2 BRAIN for a low-profile, battery-only power configuration.
    DIMENSIONS Height: 4.57 in. (116.0 mm)
    Width: 3.71 in. (94.3 mm)
    Depth: 1.42 in. (36.0 mm)
    WEIGHT 0.79 lbs (356 g)
    MATERIAL Aluminum Alloy
    BRAIN MOUNTING 4x M4 captive mounting screws
    BRAIN CONNECTIONS Power delivery via rear pogo connector (13-Pin)
    CONNECTORS P-Tap Aux Power output (2-Pin), 3.0A
    BATTERY COMPATIBILITY RED BRICK and other standard V-Lock batteries
    OPERATING TEMPERATURE 0C to 40C (32F to 104F)
    STORAGE TEMPERATURE –20C to 50C (–4F to 122F)
    OPERATING HUMIDITY 0% to 85%, non-condensing
    STORAGE HUMIDITY 0% to 85%, non-condensing
    FIRMWARE REQUIREMENT Compatible with all DSMC2 firmware v6.2 or later
    Senior Member Etienne Perrin's Avatar
    May 2015
    Paris, France
    Exactly what I need! Just ordered with the side handle, thank you Jarred!
    RED HELIUM CF #230.
    Senior Member Alberto Guglielmi's Avatar
    Aug 2015
    Great one Jarred!
    I can't wait to be able to move to DSMC2. All the stuff that I don't love about the Epic are getting better and better in the new system.
    Senior Member Demetri Zuev's Avatar
    Sep 2011
    Still on the fence if I should get this plus the standard expander, or a V-lock expander
    "Production value!"
    Senior Member ignition's Avatar
    Mar 2008
    Victoria, Australia
    IMO this plus standard expander to keep your modular options open.
    Darren Vukasinovic | Ignition Pictures
    Melbourne, Victoria - Australia
    RED Weapon 6K CF Dragon #00702 "Ripley"
    RT Mk 3.1 Motion Wireless FF, Bolt Pro 2000 Wireless TX/RX + Bolt Sidekick, Bright Tangerine Strummer DNA MB
    Camera Equipment Hire, Crew & Production Support, Dragon Aerial Cinematography
    Now that's a sexy price. And also a notable difference between the RED and Element Technica version for sure is ET's two 2-pin AUX LEMO Power outs.
    For super, super small setups you could use this DSMC2 V-Lock plate and the new REDVOLT-V straight on the camera brain.
    Total weight on DSMC2 bodies should be really lightweight. Likely sub 6lbs.
    phfx.com IMDB
    PHFX | tools
    RED Weapon 8K VV Dragon "Orochi"
    RED Weapon 8K VV Monstro "Skully"
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Senior Member KETCH ROSSi's Avatar
    Jan 2007
    ITALY | USA
    Love it...
    Is there a DSMC2 3 Point mount coming?
    The pursuit of my dreams fuels my life.
    _______________________________________
    Senior Member Kyle Dones's Avatar
    May 2012
    Grayslake, IL
    any chance of adding AUX power out like the 2x 0b 2Pin Lemo
    "As long as I can remember I feel I have had this great creative and spiritual force within me that is greater than faith, greater than ambition, greater than confidence, greater than determination, greater than vision. It is all these combined. My brain becomes magnetized with this dominating force which I hold in my hand."
    Bruce Lee
    Weapon Monstro #0218
    Weapon Helium #0137
  9.   Click here to go to the next RED TEAM post in this thread.
  #9
    Quote Originally Posted by Kyle Dones View Post
    That is what the ET version of this plate has. https://elementtechnica.com/product/...attery-module/
    May 2012
    Grayslake, IL
    Quote Originally Posted by Jarred Land View Post
    I know I was reading it while I was typing. only asked so i can decide if I'm ordering the ET. and I decided I will.
    Bruce Lee
    Weapon Helium #0137
