Click here to go to the first RED TEAM post in this thread.   Thread: RED PRO Touch 7" LCD ( Hingeless )
Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
  1.   Click here to go to the next RED TEAM post in this thread.
  #1 RED PRO Touch 7" LCD ( Hingeless )
    $2950
    http://www.red.com/store/products/re...uch-7-inch-lcd
    ESTIMATED TO BEGIN SHIPPING IN FALL 2016
    The RED Pro Touch 7.0" LCD offers a high-definition viewing experience for recording and viewing footage on your DSMC or DSMC2™ camera system. A 1920 1136 resolution display panel provides improved color accuracy, high pixel density (at 323 ppi), and 1000:1 contrast. It is also bright enough for operation in high ambient light. A robust, optically-bonded touchscreen provides the most intuitive way to navigate menus, adjust camera parameters, and review your .R3D clips directly out of the camera.
    The lightweight display mounts to your BRAIN or other 1/4-20 mounting surface and provides a LEMOconnection to connect to your camera. The RED Pro Touch 7.0" LCD is an ideal monitoring option for gimbals, cranes, and remote (away from the camera) viewing.
    For DSMC2 shooters, use a DSMC2 LEMO Adaptor A in conjunction with the RED Pro Touch 7.0" LCD for convenient mounting options away from the DSMC2 camera BRAIN. For a more ergonomic monitoring solution when you’re on the move, see the DSMC2 RED Touch 7.0" LCD featuring a fully rotating and lay-flat hinge design.
    DIMENSIONS Height: 5.24 in. (133 mm)
    Width: 7.28 in. (185 mm)
    Depth: 1.22 in. (31 mm)
    WEIGHT 1.10 lbs (549 g)
    MATERIAL Aluminum Alloy
    RESOLUTION 1920 1136
    PIXEL DENSITY 323 pixels per inch (ppi)
    REFRESH RATE 60 Hz
    RESPONSE TIME 23 ms (black to white)
    CONTRAST 1000:1
    BRIGHTNESS 350 cd/m2
    COLOR DEPTH 8-bit RGB, 4:4:4 progressive scan (16.7 million colors)
    COLORS 70% NTSC
    VIEWING ANGLE 85 all axes
    DISPLAY ORIENTATION Landscape, 180 rotation
    TOUCH Projected Capacitive (PCAP), multi-touch
    BRAIN CONNECTION Power and Communication via LCD/EVF cable
    MOUNTING 26x 1/4-20 mounting points
    2x 3/8-16 mounting points
    HOOD MOUNTING M3x0.5 5 mm (max depth)
    BUTTONS Up, Down, User 1, User 2
    POWER CONSUMPTION 5.5 W (typical)
    OPERATING TEMPERATURE 0C to 40C (32F to 104F)
    STORAGE TEMPERATURE –20C to 50C (–4F to 122F)
    OPERATING HUMIDITY 0% to 85%, non-condensing
    STORAGE HUMIDITY 0% to 85%, non-condensing
    FIRMWARE REQUIREMENT Compatible with all firmware v5.2.38 or later
    Senior Member Mark Phelan's Avatar
    Oct 2007
    Back to the future, sort of. You're going to sell a boatload of these. Might even become your most popular version.
    Nov 2011
    Brooklyn
    Nice!!
    Nick Morrison
    Founder, Director & Lead Creative
    // SMALL GIANT //
    smallgiant.tv
    Senior Member luigivaltulini's Avatar
    Oct 2009
    Switzerland- LUGANO
    Grading Suite Davinci Resolve, Rental RED Digital camera.
    WEAPON CF #831 "AUDREY"
    SCARLET-W #45 "HEIDI " , EPIC #668 .
    ARRI ALEXA EV
    SITE
    www.cine5k.ch
    www.rsi.ch
    Senior Member Reuben Evans's Avatar
    Aug 2014
    Bellingham, WA
    Very cool!
    I used my 7" DSMC2 Touch outside yesterday for the first time and it was very visible. A big improvement over the 5" Touch!
    (BTW, I think the link above for the DSMC2 RED Touch 7.0" LCD goes to an internal link because it asks for login credentials. I imagine you meant to go here http://www.red.com/store/products/ds...ouch-7inch-lcd)
    Reuben Evans
    Filmmaker
    Executive Producer Faithlife TV/Faithlife Films
    http://FaithlifeTV.com
    Helium Weapon
    Raven
    4 Scarlet MX
    RED Rocket-X
    FCPX
    DaVinci Resolve
    Sigma Cine Lenses
    Senior Member Neil Dearman's Avatar
    Sep 2012
    Atlanta/Nashville
    wow nice man!!!
    Weapon Helium 8K "MEGATRON"
    EPIC-W "Clem Fandango"
    Alexa Mini "Nashville"
    Alexa Mini "Hey Arnold"
    Zeiss CP.2 18mm, 28mm, 35mm, 50mm, 85mm, 135mm
    Gh4
    A7sii
    (4) HEDEN CARAT FOLLOW FOCUS
    (3) Teradek Bolt Pro 600
    SmallHD 1703 P3
    SmallHD 24
    SmallHD 24HDR
    (4) SmallHD 702 Bright
    (3) SmallHD 702 OLED
    [/B]
    Thank you!
    Michael Lindsay
    my studio Instagram
    Senior Member Zack Birlew's Avatar
    California and Las Vegas
    Is this compatible with all RED cameras or just DSMC2?
    Mar 2011
    Toronto, ON Canada
    Quote Originally Posted by Zack Birlew View Post
    For DSMC1 users, the lemo connects just like the old connections. No other adapters needed.
    ___________________________
    10 frame handles
    Vimeo
    Instagram
  10.   Click here to go to the next RED TEAM post in this thread.
  #10
    SWAT Brent@RED's Avatar
    Aug 2007
    Irvine CA
    Quote Originally Posted by Reuben Evans View Post
    Very cool!
    Fixed : )
