Thread: Sachtler Tripod Plate is too small, how to fix it?
Results 1 to 5 of 5
  1. #1 Sachtler Tripod Plate is too small, how to fix it?
    Senior Member AndreasOberg's Avatar
    Oct 2011
    Hiya,
    We have a Sachtler Video 20 S1 with this quick release plate: http://www.bhphotovideo.com/c/produc..._16_Touch.html
    We also have a beautiful large format camera 8x10 that we want to put on the tripod. But the 8x10s holes are a bit too wide apart for it to fit with on quick release plate. We need another 5mm or so. How do I actually solve this?
    Do I put another plate on the camera and then attach it to the Sachtler tripod, or? Something like a dovetail, cheese plate, or? Any tips on how to screw them together. So far all our equipment "just fit".
    Andreas
    www.ObergWildlife.com- Natural History Filmmaking
    www.WildlifeRescueMovie.com- Saving the animals of the Rainforest!
    CF Weapon Helium 8K Strummer Bright Tangerine, Inspire 2 X7, OConnor 2560, Canon 50-1000mm
    Senior Member Brian F Kobylarz's Avatar
    Dec 2007
    Norwich, CT. USA
    I would suggest going the cheese plate road.
    First, check that the hole spacing on the camera will match hole spacing on a plate.
    (If they are non-standard, you may need to get a piece of metal machined)
    Next, check the threads in the holes on the camera - should be 1/4-20 threads, might be 3/8-16.
    Note: Make sure the cheese plate has chamfered holes.
    Obtain the right screws (length / thread / slope on head) so that the screws will bottom out keeping a flat surface on both sides of the plate and have enough threads to secure the camera.
    Affix the plate to the camera first - (plate chamfers facing down) then attach the touch & go at approximate COG.
    Ready to go...
    Note: Best to determine the correct placement of the tilt handle before mounting the camera. The knob at the top by the rosette may interfere.
    Good luck!
    Sep 2013
    Colorado
    Attach sachtler plate to bottom of one of these and go arca swiss with it! Allows one to balance camera on tripod as well.
    http://www.reallyrightstuff.com/B2-L...-release-clamp
    or
    http://store.kesslercrane.com/kwik-r...ly-mg1001.html
    Hope that helps!
    Daniel Kelly Brown
    www.danielkellybrown.com
    Oct 2011
    Thanks a lot for the help guys. Very informative. I will do some measurements and research and see what I come up with!
    Cheers!
    /Andreas
    Hi Andreas,
    I think you need this Camera Plate. Does have only 2 slots to let you to slide Camera for better Balance.
    Let me know if you want more help.
    Michael
