Click here to go to the first RED TEAM post in this thread.   Thread: Why are Kona/Decklink HDSDI not connected to the GPU?
Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
  1. #1 Why are Kona/Decklink HDSDI not connected to the GPU?
    Jan 2008
    Ok I am not a techie but I just read a thread saying that the Kona/Decklink HDSDI are not connected to the GPU and was wondering why this is at it seems that most real time color correction and non destructive layering is now being done this way. Please correct me if I'm wrong on this but can anybody explain in lay man's terms why this is ?
    Senior Member NateWeaver's Avatar
    Aug 2007
    With Apple products it is. The output of the Color and Motion come directly from the GPU and are piped to a Kona.
    Not all applications do this, though.
    Nate Weaver
    Director/D.P., Los Angeles
    www.nateweaver.net
    Jan 2008
    Thanks Nate.
  4.   Click here to go to the next RED TEAM post in this thread.
  #4
    Piped directly to - yes, connected directly to, no. The data has to come back off the GPU, then onto the buss, then up to the HD-SDI card. The data may not be in the correct form for the HD-SDI card and need processor interaction to mangle it. Notice how once you send GPU video out your HD-SDI card it all starts to go slow?
    And hencewhy on the PC you've got Nvidia cards with direct HD SDI output built in!
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Quote Originally Posted by Graeme Nattress View Post
    Graeme
    Graeme,
    Is there a plan for a V-OUT from RED ALERT or REDCINE?
    I'd love this feature.
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
    And works well!!
    so basically its a software developers problem that aren't able to develop a proper code and are obliged to use a hardware solution witch is implemented only in Nvidia SDI cards.
  7.   Click here to go to the next RED TEAM post in this thread.
  #7
    No, it's purely a hardware issue! Even if the data does not need to be reformatted it still needs to come back down from the GPU which is slow, and go across the buss to the other card. The only efficient way is for the SDI output to be on the GPU card so the image always flows forwards and never backwards.
    Graeme
    Understood Graeme thanks...
    Norway
    So, any idea why the "creative" apple does not support this?
    Gunleik
    (slowly becoming a hater of Apples ProApps as my Red experience moves on...)
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Sep 2007
    good old Berlin
    Quote Originally Posted by gunleik View Post
    Gunleik
    did someone reported how a CC software works under bootcamp and a quaddro?
    red is not a color, it's a camera.
