Thread: RED RAVEN - Info and Data Sheets
Page 9 of 9 FirstFirst ... 56789
Results 81 to 88 of 88
  1. #81
    Senior Member Alvise Tedesco's Avatar
    Milan Italy
    Phil, do you happen to know if the Raven draws less power than Weapon?
    Months ago I made myself a note with the 50W figure. I suppose I noted this cause of words from Jarred or Brent. But I'm not sure anymore
    Unfortunately It looks like It will be closer to (old MX) 60W than 50W, correct?
    Thanks for helping
    Feb 2013
    http://www.red.com/tools/crop-factor
    Are the existing calculators for dragon accurate for Raven if you just use dragon 4.5K?
    Senior Member Adam Welch's Avatar
    May 2008
    Waukee, IA
    Phil I know you are a very busy guy, but you had a very nice & helpful data sheet/guide for the Epic & Scarlet. Will you be making something like that for the Weapon, Scarlet-W, & Raven?
    Quote Originally Posted by Adam Welch View Post
    Absolutely. Waiting on a few things that are in the works to get hammered down. But as Yoda says, "There is another".
    Stay tuned.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Dec 2010
    Hi Phil,
    what is it regarding the compression on Scarlet-W vs Raven? In some cases at certain frame rates it seems to be better on Raven.??
    Is that for real??
    Senior Member Aaron Lochert's Avatar
    Oct 2013
    Tucson, AZ
    Quote Originally Posted by Jiri Vrozina View Post
    Hi Phil,
    Is that for real??
    Remember, full frame readout on the Raven is actually 2.1:1 aspect ratio, which is 4608 x 2160. Full frame readout on Scarlet-W is a taller aspect ratio of 1.9:1, or 5120 x 2700. This means that "4.5K FF" on the Scarlet-W utilizes that same aspect ratio and is 4608 x 2412.
    Even though they're both called "4.5K FF" on the DSMC Media Guide chart, the Scarlet-W is recording 252 more lines, or 1.1 more megapixels than Raven.
    The closest thing you can compare with would be the Scarlet-W's 4.5K 2:1 to the Raven's 4.5K FF, but the Raven is still recording less vertical resolution and therefore can have lower compression rates.
    Nov 2007
    Leksand, Sweden
    I have no Red camera yet
    My Sony EX have HD 1080p 30fp and 720p 60p. I understand how to use those rates, which work well with my computer and TV.
    But how do the various rates of Raven work with my equipment? Slow Motion would not be a problem, but when using high frame rates, what happens? If I e g want use time base 25 fps and frame rate 60 fps to get better motion, will my computer cope with the increased data rate, which will be much higher than from my Sony EX?
    Senior Member Kirk.Attard's Avatar
    Jan 2011
    Malta
    Will there ever be a Helium raven? Or is too early to tell?
    Epic-X #6700 (Aquila)
    Nov 2010
    Washington DC
    I think there will probably be another cheaper option for Helium when some of the dust settles
    Scarlet-W 9706
    Alexa Mini
    Toronto, Canada
    Can anyone confirm if it is possible to mount the DSMC2 Red Touch 7.0" on the side Pogo connectors, like in Phil's photo above? This seems like a much better place to mount an LCD than the top, which most people seem to do. If side mounting works, what are the disadvantages to mounting it here? Are there clearance issues? Limited tilt angles?
    Thanks!
