Thread: RedLink compatible lenses (EF/Nikon mount with remote control)
Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 56
  1. #11
    Senior Member Lauri Hakala's Avatar
    Apr 2010
    Finland
    Sigma Art 35mm f1.4 EF and Canon EF 70-200mm f2.8 L USM (non is) are also working good.
    Senior Member Michael Kromschroeder's Avatar
    May 2010
    Munich - Germany
    Whoa wait? So THC works with redlink protocol directly? Like you wouldn't need foolcontrol? Does it do start/stop and everything?
    Also, how hard is it to recalibrate if a lens loses calibration (specifically the Sigma 18-35)?
    So THC works with redlink protocol directly? YES!!
    Like you wouldn't need fool control? YES
    Does it do start/stop and everything? YES it does start/stop, it does focus and plus iris!
    Also, how hard is it to recalibrate if a lens loses calibration. With the THC you just push the calibrate button
    DoP | Cinematographer | DiT | EPIC-M DRAGON #933 + EPIC-X #5292
    www.mediabit-film.de
    - Making movies is about passion - about empathy and dedication
    May 2010
    Munich - Germany
    Quote Originally Posted by Gunleik Groven View Post
    Michael K can probably fill in what you exactly need to get that up and running.
    I use the REDLink Bridge directly with Foolcontrol and the T.H.C., nothing else is needet
    Michael, do you got the WMD also?
    As I understand that one is one of the few lens controllers that can collect focus / iris data and even gyro stuff from camera, no?
    don't know anyone that use those two so very curious to know how they work.
    The THC on weapon and EF glas will be pretty clean. Add lens pull focus / iris and nothing to it. Think RED should market that a bit harder, the price for the THC is not bad considering what it does and that it can be complimented with the WMD that is the only true way of collecting lens/camera data etc.
    What is the price difference between optitron 2 and the THC?
    Edit: Optitron 2 1900USD THC: 2900USD
    Björn Benckert
    +46855524900 www.syndicate.se
    Flame / VFX / Motion capture / Monstro
    May 2010
    Munich - Germany
    Quote Originally Posted by Björn Benckert View Post
    Hi Björn,
    no I don't own the WMD.
    REDuser Sponsor Gunleik Groven's Avatar
    Norway
    Optitron wireless unit is actually in the 750 USD range, so the price difference is smaller.
    But you'd have to add the WMD to get the functionality you (and I sorta) are looking for.
    WMD is 3.950 USD
    And you'll also need a REDlink Bridge according to Mikael L: 395 USD if you don't use it with the WMD.
    Price is on Optitrons side, if you don't want to record metadata.
    What we're looking at is a splitter for the ctrl port, as we need to send and read other metadata over redlink than the Optitron controls.
    Life is good. So is RED...
    http://quine.no
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    WMD is 3.950 USD
    Or we can find a gigabit router and use wifi to send camera controls via the ethernet port.
    I wish Red could lower the requirements to 10-100 ethernet. That would open up a slew of possibilities.
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
    Norway
    Quote Originally Posted by Jacek Zakowicz View Post
    sure.
    would the optitron be able to hook up to that?
    http://quine.no
    Jun 2008
    sure.
    No OptiTron uses its own wireless protocol to make sure that the connection is stable and robust. We don't take chances that could jeopardize production ;-)
    Here are the results of my first tests using the Optitron 2 and Canon EF lenses:
    Tokina 11-16 f2.8: Works flawlessly
    Sigma Art 18-35 f1.8: Works flawlessly
    Canon 24mm f1.4 L II: Works flawlessly
    Canon 35mm f1.4 L: Works flawlessly
    Canon 50mm f1.2 L: Works flawlessly
    Canon 85mm f1.2 L II: All features work, but it seems more "steppy" on huge focus pulls than shorter lenses. For normal pulls, it worked flawlessly.
    Canon 100mm macro f2.8 L: Appears very "steppy" on long pulls, but how often do you do big pulls in macro work anyway?
    Canon 135mm f2 L: Again, appears more "steppy" compared with the shorter focal-length lenses.
    Unlike others reporting above, I had no issues at all with the 24mm and 35mm lenses, which is fortunate, as those are two of my three favorites in the kit!
    Stephen
    Scarlet Dragon with Canon, Sigma, and Tokina lenses and the Optitron 2 wireless focus system
    First feature film, Works in Progress, out on DVD (Vanguard Cinema) and online.
    Second feature film, the miniseries Terminal, currently available on Amazon: https://www.amazon.com/dp/B07R8RQ488
    Third feature film, The Tree, currently available on Amazon: https://www.amazon.com/dp/B07JJ179RP
    Fourth feature film, The Land, currently under review at film festivals around the world.
