Thread: Encoding for REDRAY tutorial
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 Encoding for REDRAY tutorial
    Junior Member
    Jan 2010
    London, UK
    Hello,
    I'm trying to encode material for a REDRAY player and I'm struggling. I have looked through the forums and searched for instructions but can't find anything.
    I have got as far as creating a 16-bit TIFF Image sequence. I have RED CINE X PRO 35.1 with a REDRAY licence.
    This is where i'm stuck. I believe I need to encode to the .RED codec.
    Can anyone advise? Or point me in the direction of a tutorial video or anything that will help?
    Many thanks
    Stephen
    Senior Member Chris McKechnie's Avatar
    Mar 2011
    Dallas, TX
    If memory serves me correctly, you have to backdate your RED Cine X (can't use the latest version). I forgot exactly which version supports redray encoding...maybe someone else could chime in. That's what your issue is. I think it was around version 22 something.
    Chris McKechnie
    Director of Photography
    Email - redepicguy@gmail.com
    Reel - https://vimeo.com/314919326
    Ahoy. I have help for you Stephen.
    - Download the newest REDCINE-X Pro.
    - Under Edit>Preferences>REDRAY sign into your account and install the plugin.
    - You will then want to create a new tab on the right of the GUI for "REDRAY" (next to Look, Framing, Metadata, Etc)
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    San Diego, CA
    Great info Phil. Thanx.
    Cheers - #19
    Nov 2008
    Dallas, TX
    Was there ever an official announcement regarding redrays death?
    JAKE WILGANOWSKI
    Director of Photography / Filmmaker
    CINE-AUTOMATIC.COM
    Mar 2011
    Dallas, TX
    That's why they call him...RED Master Phil Holland
    Chris McKechnie
    Junior Member
    Jan 2010
    London, UK
    Hello,
    Thanks for the replies. I'll give that a go and report back.
    Cheers
    Junior Member
    Jan 2010
    London, UK
    I've got are far as encoding the TIFF sequence into the .RED codec. It's roughly a 26minute film, I now have 30 separate .RED files all around 2GB each.
    I used a 32GB USB 3.0 Flash stick. I formatted it in OS X Disk Utility to MS-DOS (FAT). I then created a top level folder named 'Contents' and dropped 3 of these .RED files into this folder.
    I couldn't drop them all in as the stick is 32GB and the total of all 30 files is 66GB. So I thought I would test with a few files.
    I plugged the USB stick into the front of the RED RAY and nothing. I waited and nothing happened.
    I also tried with a USB 2.0 100GB portable drive. I copied all the 30 .RED files into a folder named 'Contents' and tried that. Still nothing.
    The user manual states 'The REDRAY can interface with the following types of physical media: USB 2.0 flash drive'
    Does the USB stick have to be USB 2.0 only? I used a USB 3.0 stick.
    Any other ideas?
    Junior Member
    Jan 2010
    London, UK
    Sorry, the name of the folder I made was “Content”. Not as previously mentioned.
    Senior Member Eric Santiago's Avatar
    Oct 2010
    Canada
    I was using the old v21 (?) for a long time, since when was this updated to the new versions?
    < Someday I'll be cool enough to have something witty here >
