Click here to go to the first RED TEAM post in this thread.   Thread: Long Exposures
Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. #1 Long Exposures
    Senior Member Linda Barzini's Avatar
    Dec 2009
    Chicago
    Is there any way of overriding the 1fps and set an exposure of 30 seconds to do a timelapse of stars?
    Moderator David Battistella's Avatar
    Florence, Italy
    The red uses an electronic shutter. The maximum exposure duration is 1/2 second. You can use frame averaging modes in which the camera makes up to 16 half second exposure and combines them into a frame. In these modes you can see the movement of star fields.
    "Colors are the wounds of light."
    -William Blake
    Dec 2009
    Chicago
    About halfway there.
    Florence, Italy
    Not quite. I've used this mode, you should try it the results are impressive.
    -William Blake
    REDuser Sponsor Martin Stevens's Avatar
    Jan 2007
    Massachusetts
    Quote Originally Posted by David Battistella View Post
    Can you post some samples?
    Regards,
    Martin Stevens
    President and Founder of Glidecam Industries, Inc.
    Producer and Director at Metaphoric Pictures Corporation.
    Florence, Italy
    Well
    you won't see into deep space but you can see stars moving over long time lapses.
    -William Blake
  7.   Click here to go to the next RED TEAM post in this thread.
  #7
    For any long exposure work, frame averaging is the way to go. It gives you the longer exposure you want, but it also significantly drops image noise allowing vastly higher ISO without significant penalty. If you're doing a 16 frame average, shooting at ISO6400 looks as noise free as you could want.
    Graeme
    www.red.com - 8k Digital Cinema Camera
    Science enables stories. Stories drive science
    IPP2, Image Processing, Colour Science and Demosaic Algorithms
    Senior Member Burke Doeren's Avatar
    Jan 2011
    Santa Monica, CA
    Agreed. I tried frame averaging for the first time a few months ago and it was spectacularly clean.
    Just make sure you black shade for 1fps first to get the best results.
    Burke Doeren
    BURKE DOEREN PRODUCTIONS
    Santa Monica, CA
    Director | Cinematographer | Visual Effects
    www.BurkeDoeren.com
    Jan 2007
    Massachusetts
    Quote Originally Posted by Graeme Nattress View Post
    Graeme
    Can you post image examples to show this feature off?
    Regards,
    Martin Stevens
  10.   Click here to go to the next RED TEAM post in this thread.
  #10
    http://www.graemenattress.com/wp/160-pg-unicorn-2/
    Dragon LLO OLPF. I'm stopping down to get the DOF I need for the shots, so that's why I'm using the averaging mode. It works better than even a perfect long exposure as it doesn't just ensure enough integration time to make the correct exposure, but also drastically lowers noise. Most shots there are ISO3200, the darker ones ISO6400.
    Graeme
