Click here to go to the first RED TEAM post in this thread.   Thread: Announcing Element Technica V-Lock Module for Weapon
Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 75
  1. #31
    Quote Originally Posted by Christopher*Seguine View Post
    Any Photos of V-Mount battery on the body?
    With the shorter body and LCD mounting point seems like V-mounts will either obscure the LCD or block the rear lower vents.
    How do the battery plates attach, screws or quick release?
    Doesn't look like it goes below the rear and blocks the vents.
    The AB and V-Mount Modules attach to the brain or other modules with bolts.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Quote Originally Posted by Christoffer Glans View Post
    I'm curious. Since some modules for Epic Dragon work on the Weapon, wouldn't these third party modules work on Epic Dragon as well, not just Weapon?
    Not compatible as long as red does not make some sort of "bridge module". different camera backs...
    Björn Benckert
    +46855524900 www.syndicate.se/axis
    VFX / Flame / Motion capture / Monstro
    Senior Member Andreas Mendritzki's Avatar
    Oct 2008
    Montréal, Canada
    Looks good.
    Andreas Mendritzki - cineground.com -
    RED Rentals in Montréal, Canada
    CF Weapon 810
    Epic-X 1239
    Scarlet-X 150
    Red MX 4529
    Leica Summicron-C, Cooke MiniS4, Kowa Anamorphic & more
    Senior Member Jon Carr's Avatar
    Aug 2009
    NYC
    Why can't this come with the Weapon upgrade package? So much more useful then the redvolts XL module.
    Dp Reel
    http://www.joncarrdp.com
    Camera & Lighting Rentals in NYC
    http://www.visualcinema.com/rentals/cameras/
    Instagram
    http://instagram.com/joncarrdp
    Carbon Fiber WEAPON Helium #651 "MISTRESS"
    DJI Ronin 2 “R2D2”
    Schneider Xenon FF primes PL
    It's REDcode or no code...
    Nov 2011
    Toronto
    No offence Phil but I can't see why P-Tap wouldn't be incorporated in this or any level of body. Lemo is better, we all know this, but options are even better still.
    I travel a lot for shoots and rent many accessories locally. Sometimes last minute; client requests some kind of specialty shot and we need to quickly source some specialty gear. I don't know if they'll come with a 2-pin (or 4-pin, sigh) Lemo cable, sometimes they do and then I'll use that, but they almost always have a P-tap cable. (great example is the power cable for the Cabrio 19-90 Servo unit... I've never seen one that wasn't P-tap)
    A big part of my job is being prepared for anything. Dual P-taps and a DC in will help me do that.
    With this my options are:
    A) Buy Lemo cables for accessories that I A) don't even own B) don't know if I'll ever even need to use C) Have never even heard about
    or
    B) Use that fancy Lemo to P-tap splitter from Off Hollywood, which kinda negates the gains in the new Weapon design (less cable clutter). Not even sure how to mount that to Weapon right now...
    Why not just incorporate P-taps into the battery plate? Make it a one-off just for me if you have to, I'll pay for it. (I'm certain more people would want this too)
    Whatever happened to "the customer is always right"?
    Banned
    Nov 2011
    California
    So a v-mount battery would then stick up pretty high compared to the body and be pretty hard to use the LCD in its fixed cable free position.
    Probably have to count on using the lemo adapters modules to re-position the LCD if you want to use v-mount batteries on board?
    Senior Member Jordan Buck's Avatar
    Feb 2013
    London, UK
    No P tap might be the decider for me, that makes no sense, I have always powered TV logic, WFF, teradek, almost everything through it.
    Hopefully a few other people quickly make V mount backs that have a ptap on it.
    RED Epic Dragon #03820
    http://www.jordanbuck.co.uk
    Oct 2008
    Queenstown, New Zealand
    Thanks Phil, my thoughts as well. For me, it's pretty important to have a V-Mount go straight onto the back of the camera without adding extra modules.
    I also had this issue with 2 pin lemo only and travelling and needing to put P-Tap power out. A solution I found was a splitter cable made by Letus.
    It's been quite useful, and now travels with me.
    Ben Ruffell
    Director of Photography
    www.benruffell.com
    Senior Member Jeffrey Loewe's Avatar
    Aug 2011
    CO and UT
    Curious, If you decide to go this route instead of say a RV XL module, can you reassign that portion of your order to something of similar value?
    Senior Member PatrickFaith's Avatar
    Nov 2011
    California
    Quote Originally Posted by Jeffrey Loewe View Post
    I wish, I will ask tomorrow mourning ;) all my batteries are gold mount nowadays, so would be nice (I have had bad luck on all 4 of my volt batteries and two chargers). Btw having ET and guys like that in the red booth is great, and is so nice that abelcine is involved since I can buy my et stuff through abelcine. It's a whole new extended family.
