Click here to go to the first RED TEAM post in this thread.   Thread: Focus not registering.
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 Focus not registering.
    If I send:
    #$EXT:S:FOCUS:1400:\n
    Code:
    23 24 47 44 52 41 47 4f 4e 3a 53 3a 46 4f 43 55 53 3a 31 34 30 30 3a 0a
    I get nothing.
    If I send:
    #$EXT:G:FOCUS:1400:\n
    I get
    #$GDRAGON:C:FOCUSF:142:\n
    Code:
    23 24 47 44 52 41 47 4F 4E 3A 43 3A 46 4F 43 55 53 46 3A 31 34 32 3A 0A
    Any idea why it's not setting focus? Do I have to set both near and far? Can I not set specific meters?
    I do get:
    #$GDRAGON:C:FOCSCTRL:1:\n
    Senior Member Mikael Lubtchansky's Avatar
    Jul 2007
    France
    Gavin, which AF MODE are you in ?
    G:AFMODE
    foolcat : HTML / PDF visual reports for OS X
    foolcontrol : RED camera control for OS X
    foolcontrol : RED camera control for iOS
    foolcontrol : RED camera control for Android
    foolcolor.net staying hungry, staying foolish facebook instagram
    Code:
    #$GDRAGON:C:AFMODE:1:\n
    Oh the lens needs the switch to be set mechanically to AF. Duh. Damn you real world problems!
  5.   Click here to go to the next RED TEAM post in this thread.
  #5
    Also, if you are trying to do precise focus movements use HCFOCUS instead. It is unitless - so you don't know what focus you are setting, but it has much better granular support. HCFOCUS is intended for use for things like follow focus.
    Quote Originally Posted by Trent Lillehaugen View Post
    I just tried sending a few HCFOCUS codes and sending "10" or "30" put it to 1'3". Sending "100" sent it to inf. It's not corresponding to the 0-65365 range.
    Jul 2007
    France
    HCFOCUS requires the camera to be in manual AF mode ? lens still needs to be on AF tho.
    S:AFMODE:0:
    Yeah I switched over to AFMODE:0 same behavior. 0 gives me 1'3" 50 gives me infinity.
    Is the hex correct that I'm sending?
    Code:
    23 24 45 58 54 3a 47 3a 48 43 46 4f 43 55 53 3a 33 35 30 30 30 3a 0a
    That should be:
    #$EXT:G:HCFOCUS:35000:\n
    but I'm getting
    #$GDRAGON:C:HCFOCUS:0:\n
    in return. EVen if the focus is physically not-on close focus.
    If I try sending a HCFOCUS with something like this:
    #$GDRAGON:S:HCFOCUS:5000\n
    Code:
    23 24 47 44 52 41 47 4f 4e 3a 53 3a 48 43 46 4f 43 55 53 3a 35 30 30 30 0a
    I get MPITCH as the first response.
    Ok tried this (raw encoding as UINT16 the distance thinking that might be the problem but no dice:
    23 24 45 58 54 3a 53 3a 48 43 46 4f 43 55 53 3a a4 f6 3a 0a
  10.   This is the last RED TEAM post in this thread.   #10
    Quote Originally Posted by Gavin Greenwalt View Post
    Code:
    That should be:
    but I'm getting
    Code:
    Your example SET string is missing the trailing colon:
    This should be:
    #$GDRAGON:S:HCFOCUS:5000:\n
    Before using any of the HCFOCUS/IRIS/ZOOM commands you should use HCREINIT (this should calibrate the end points)
    This makes me think you don't quite understand the RCP flow. you are not guaranteed to get "responses" to your SET commands before you get other packets. Everything in RCP is asynchronous. Futhermore, we don't send out CURRENTS for the HC* commands as it would overload the system if someone was using a real (or simulated) hand controller.
