Thread: 4K over HDMI from Red Dragon ??
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Oct 2009
    Dresden, Germany
    While I wouldn't put it past Red to design something with HDMI 2.0 included in a module, I imagine it would likely happen in the next brain or even possibly through a camera upgrade itself.
    HDMI1.4 can do 4k, up to 30hz at UHD and 24hz at real 4k.
    The HDMI-chips in Dragons and maybe even MX brains might be capable of doing that. But the more tricky question is, can current brains internally debayer to 4k? The existence of the Broadcast-4k-module might be the answer to that.
    Maik Mueller || http://www.maikmueller.art
    RED Scarlet-X/DRAGON #1388
    Zeiss Otus 28/1.4 & 55/1.4 & 85/1.4
    Senior Member Jarek Zabczynski's Avatar
    Poughkeepsie, NY
    Quote Originally Posted by Maik Müller View Post
    Just to remind you of something what RED previewed a while ago: tethered recording over Gig-E. There is lots of potential, with live monitoring and streaming in full-res(!) over a laptop being one of the possible applications. Transcoding to 4k on a computer, with ROCKET-power and realtime-colorgrading? Should be doable. ;)
    Yeah, thats not a module, but maybe a even better solution for some scenarios.
    I hope RED gives access to that via their SDK.
    So theoretically, couldn't there be an external recorder type device that takes the Gig-E input and is able to debayer that, record it to prores etc, and or, send out a 4k signal via HDMI?
    Shoot for the Impossible...Then do it.
    Jarek Zabczynski
    Director / Editor / Cinematographer
    Weapon 8K | www.jarek.com | WE'LL BE ALRIGHT (Music Video) | BAJO EL SOL (Music Video)
    San Diego, CA
    I wonder how much latency would result from Jarek's theoretical pipeline? Measured at the image displayed from the HDMI spigot would it appear in sync?
    There are a lot of valuable use cases possible with the GigE live out feed even if there is a little latency, and even more if there isn't...
    Cheers - #19
    Oct 2009
    Dresden, Germany
    Quote Originally Posted by Jarek Zabczynski View Post
    Thats what i'm talking about, but i was thinking about a software-solution for all those (fast enough) new laptops with UHD-screens and HDMI2.0-ports or a "PC in a small box".
    Dedicated device, doable, but way more complicated. Getting some chips to debayer RED-footage, with all the licences and a so on? ;)
    Oct 2009
    Dresden, Germany
    Quote Originally Posted by Blair S. Paulsen View Post
    Between this and the image you see through the brains HDMI/SDI or on the RED-LCD there will be a visible delay for sure.
    Senior Member Jeffery Anderson's Avatar
    Jul 2012
    ATL
    If haven't already see this:
    http://www.red.com/store/products/rear-ssd-module
    Here's the tethered recording
    http://www.reduser.net/forum/showthr...nd-Photokina-)
    Be cool if this could be a wireless wifi thingy...
    I have to try and change the landscape, whatever it is.
    -Robert Plant
