Thread: Compression Wedges
Page 5 of 5 FirstFirst 12345
Results 41 to 45 of 45
  1. #41
    Banned
    Jul 2012
    re: motion tests
    if you're not really geeky..skip this post btw
    my personal tests have always focused on low light. and in that regard 22:1 is always much much less noisy, in terms of "low light" originated noise, than higher compression options..and this is what id expect, as the noise gets thrown away in increasing amounts as compression is increased.. its what the wavelet transform is all about afterall..seperating signal from noise.. which in reality means throwing away small values.. which in reality sometimes means stripping bark off trees.. but whatever, compression is necessary for practical reasons..
    what this test is showing is codec introduced artifacts.. but its worth noting that trees are the ultimate stress test for redcode, and wavelet quantization and compresison distribution. and if your not shooting in a forest..22:1 is totally usable ..and IMO, if you're not shooting closeup stills for the front cover of "tree bark weekly" .. probably fine in a forest also, especially if you're going to downsample to 4k..
    5:1 is not my sweet spot, 12:1 is..10:1 in a forest ;) ..and thats on the mx, at 5k
    i have not yet found an economically viable way of storing footage long term
    crime and punishment was shot at 10:1 @ 4k on mx btw .. 5:1 is simply not an option for most
    there is one test i have always wanted to do, but never completed fully. that is to count how many individual ie original, 48bit RGB colours you can find in any given red image
    ..turns out its not a trivial calculation, so i have never managed to calculate a value that analysed more than about 75 lines .. i am still working on the problem though
    one way to find this value is to use a giant lookup table, which needs to be 65536 * 65536 * 65536 in size if we are to believe we are capturing 16bit raw values.. or 4096*4096*4096 if we are capturing 12bit (im still pretty irritated that apparently we're not allowed to know when the camera is recording 12 or 16bit.. but hey..).. or 65536*65536*65536 if your camera manufacturer won't let you know what you are recording, or when.. but llikes to have bigger numbers in their specs for reasons of corporate insecurity no-doubt.. never the less..
    ..both arrays are too large for most systems.. so another method is to use a dynamic array and only add values that don't already exist in the list.. and keep a count of original values..in which case you need an array that is 6000x4000 approx.for a 6k image.. ..which does fit into my RAM..but again, after analysing about 75 lines the search for "individuality colours" gets pretty slow.. and every line you analyse makes it slower still..
    a third way to calculate if a value is original is to create a fiename with the value concatenated. the number of files you have created is the number of original colours. if a colour has already been seen it merely overwrites its corresponding file with an identical one... but unfortunately most micro computers (macs or pcs ) .. can't handle more than about 20000 files in a folder together, so again the analysis becomes critically slow after about 50 lines like the other methods,but for different reasons. for a 6k image you might generate 6000x4000 files etc.. substantially more than most non-cray computers can generally handle..
    an alternative to the above is to use each colour component value (R, g and B) as a folder name..but this also becomes very slow .. but at a slightly slower rate.. if that makes sense.. i think this sytem got me to line 75 .. the number of sub-folders is your original colour count..
    anyway, whatever image ive tested, up until the point the calculation gets too slow and ive bailed..usually after analysing about 50 lines.. and whatever horizontal line i start the analysis on..as i can choose that.. i seem to get a value of between 22-30%
    ..meaning between a quarter, and a third of pixel colours are not original.. and seems a very high number given the extremely low probability that three independant colour values ranging between 0..65535 will all be identical to another three values with the same range, within a finite set of just a few thousand samples.. of course.. some of those values are interpolations generated by the debayering .. but its still a high percentage
    so it is in this way that i have analysed rc image compression. the quantization is certainly there in all compression ratios. im looking forward to testing output from an aja or ursa actually for comparison in regard to "original colours"
    ..still trying to find the best method ..maybe three arrays.. <ignore me now, im thinking out load> ..
    Quote Originally Posted by egon touste View Post
    What this test is showing is codec introduced artifacts.. but its worth noting that trees are the ultimate stress test for redcode, and wavelet quantization and compresison distribution. and if your not shooting in a forest..22:1 is totally usable ..and IMO, if you're not shooting closeup stills for the front cover of "tree bark weekly" .. probably fine in a forest also, especially if you're going to downsample to 4k..
    It should be noted that it wasn't full frame trees, these just happen to be in frame. Most of the frame is pretty low detail. Also the artifacts creep up even on perfectly smooth surfaces (see the piano tests which have no Gifs but demonstrate chroma flicker even on a flat floor). The problem isn't the loss of detail the problem is that you get macro-flicker and shimmer. And it's visible like on the trees in almost every shot I've ever seen at high compression. Someone just posted a HDRx reel here on REDUser and almost every single shot had clearly visible compression flicker because it was HDRx and therefore by definition highspeed.
    Banned
    Jul 2012
    Quote Originally Posted by Gavin Greenwalt View Post
    ..i agree.. but re: redcode .. i just cut my cloth ..and my cloth is relatively small
    ps, did they post an r3d showreel.. or a compressed one?
    ..the artifacts are more noticeable on flat objects..anything "dark" suffers too.. day or night.. its the codec, not the sensor making the choices..
    i shot in near darkness in a large london studio on saturday, shooting black artists, wearing mostly black, in a black studio.. no planning, no real lights, called last minute..luckily we got three cars in there and used headlights creatively..
    i didn't look at the footage on set..too busy winging it.. but by the time it hits 1080p it should be ok ..<fingers crossed>
    Senior Member Christoffer Glans's Avatar
    Jun 2007
    Stockholm, Sweden
    Shoot according to scene.
    Night, high ISO = lower compression (3:1 or 5:1)
    Forest or high detail with lots of movement = (3:1)
    Sunlit day, low ISO, flat surfaces, low to no motion = (12:1 and above)
    Sunlit day, moderate ISO, flat surfaces, high motion = (9:1)
    That's how I use it and it saves a lot of storage space.
    "Using any digital cinema camera today is like sending your 35mm rolls to a standard lab. -Using a Red is like owning a dark room."
    Red Weapon 6K #00600
    Senior Member Jason Kraynek's Avatar
    Oct 2013
    Chicago
    Lower frame rate.
    Do you have a chart that shows what frame rate for what compression Phil?
    Cinematographer | Director | Editor | Colorist | Writer
    http://jacenk.net - Epic Dragon #6625 "Leelu"
