Thread: Compression Wedges
Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
  1. #1 Compression Wedges
    Table of Contents
    I did a bazillion compression wedges. Not terribly interesting to look at but the data should be useful.
    Process was to take every resolution and reformat to 6k to maintain scale. All framing was equal. Focus I think was dead on. I did it by eye with focus and edge enhance modes for focus. Lens wasn't the sharpest lens in the world: Canon 24-70 L II and focal range was about 45-65. DXO says that all of those focal lengths should have similar lp/mm. Left half is center of frame and focal point. Right half of frame is edge of frame and a little out of focus to highlight flatter less detailed image regions.
    It's also very revealing to look at these in Hue Saturation and Value modes. REDCode definitely hits Hue and Saturation much more aggressively than it does luminance. As a result the noise pattern changes dramatically from 2:1 uncompressed to even 8:1 uncompressed. If you want fine noise you really want to shoot at nearly uncompressed.
  5. #5
    Jan 2010
    San Diego, CA
    How did you capture 6K 2:1 compression?
    EPIC-X DRAGON 2109
    Quote Originally Posted by Andrew Huse View Post
    Lower frame rate.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Junior Member Dan Dyer's Avatar
    Jun 2014
    Denver, CO
    I was getting ready to do something just like this. You just saved me a ton o time. Thanks!
    Dan Dyer
    Red Scarlet Dragon
    Denver, CO
    Jan 2009
    Los Angeles, CA
    Nice work! Thanks for this!
    Director / Photographer / Designer
    www.work.charlesbergquist.com
    www.everyday.charlesbergquist.com
    Weapon MONSTRO 8K VV
    Weapon DRAGON CARBON 6K S35
    Scarlet-W 5K
    Phantom Flex4K 128GB
    Los Angeles, California
    Banned
    Apr 2013
    Montreal - Toronto - NYC
    Extremely informative and useful. Thank you! The biggest draw for me, of Epic vs Scarlet was the lower compression, which few people seem to think about.
    Feb 2007
    5:1 compression still seems like the sweet spot.
    Of course, 3:1 is better but to achieve fluidity on set (i.e. not change mags every few minutes) 5:1 is perfectly acceptable.
