Hello all
NAB is over, so as promised, foolcontrol pre-release try out version is available for download.
Get it from the webpage : foolcolor.net/foolcontrol
It works with GIG-E cable or REDLINK bridge connection.
Demo version should let you try the app for 5 minutes or so then lock you out for 15 minutes, then you can try it again etc
I'll add more info on this page in the coming days but have to take my plane back from Vegas in few hours...
Feedback, bug report or feature request can either be sent to this thread or directly by email.
Have fun playing with it and thanks for those who already purchased a license during NAB.
It runs on Mac OS X 10.8 and up with a REDLINK bridge module or a lemo to CAT5E GIG-E cable (REDstore cable link)
You will need to set up the connection on camera and computer so they are on the same network before you can connect (Ad-Hoc or infrastructure for wifi. DHCP or manually + enabling External Control for gig-e).
(see bottom of webpage for detailed connection setups)
This pre-release version lacks a few features that I will be quickly adding in the coming weeks.
If your computer is connected to the internet while launching the app (and not always directly to the REDlink ad-hoc network) check in the lower right if a new version is available for download.
Upcoming features :
- auto-update
- camera audio input and output levels
- zebra
- auto exposure tools
- save in / out points in playback mode
- more parameters logged into activity report
- proxy recording using video input in record and playback
- full and partial lock of the UI to avoid any accidental setting change
- integration of more USB devices support (tangent element 12 knobs panel,...)
and :
- some multi cam support
- whatever else you may suggest
You will need a BlackMagic DeckLink or UltraStudio (like the TB mini recorder) to use the foolscreen features (video preview, snapshots, still image overlay). May add AJA support later.
Check the '?' at top right of main window for keyboard shortcuts.
No manual yet but everything should be easy do understand...
Do not hesitate to click on any text to reveal local menus or activate / reset buttons...
Get in touch if you have a USB controller like the Griffin PowerMate (basically you can map the rotation to left right arrow keys for focus, or up/down arrows for aperture, and assign press to Z for magnify or press and hold to R for record toggle)
The app hasn't been tested on too many OS X configurations so please contact me if you run into an issue with it or have any question.
Hope you'll like the app and send some feedback
