Click here to go to the first RED TEAM post in this thread.   Thread: RELEASED: BETA FIRMWARE - BUILD 15 (v2.1.7)
Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
  1. #41
    Senior Member Philip Lima's Avatar
    Nov 2007
    The 48v is works, but the instant it is turned on, there is a terrible hiss in the system and the audio quality is terrible. When we turn it off and use a standard, self-powered mic, it sounds perfect.
    http://www.reduser.net/forum/showthr...t=10285&page=3
    From what I've read here, we aren't the only ones with the issue. We are using the cable that was included with the camera.
    Any ideas? Are we the only ones having this issue?
  2.   Click here to go to the next RED TEAM post in this thread.
  #42
    Thanks for the clarification. I found out that our firmware experts are on the case.
    BC
  3.   This is the last RED TEAM post in this thread.   #43 +48v
    Red Team Stuart English's Avatar
    Irvine, Ca
    Yes we are indeed on the case.. and this is not related to the earlier hiss issue.
    Workflow Wizard
    How hard would it be to make the little DC label flash when the voltage drops below a certain threshold?
    Senior Member Kyle Mallory's Avatar
    Jan 2007
    Salt Lake City
    Quote Originally Posted by rgdfilmsRED View Post
    Still get the flickering..
    Yesterday I was shooting 2k 2:1 RC28 120fps to the Red Raid and I was getting dropouts galore.. Camera was stationary.. Also, tried 113 fps on the CF card and dropouts as well..
    Running the latest firmware (2.1.7), I've been shooting 2k 2:1 120fps all weekend long to the RED RAID, without any trouble, and no LCD flickering. Do you have any other footage on your drive?
    Kyle
    Jan 2007
    Salt Lake City
    Related to the LCD, I have had a problem with the LCD showing only blue when the camera is first booted. If I disconnect and then reconnect the LCD, it works fine.
    Anyone else seen this?
    Nov 2007
    kylemallory,
    We too have had this issue a few times in the field. The first time it happened, the camera didn't finish booting and actually reset itself somehow. A few hours later, after shutting it down for a while, the screen was blue after booting until we disconnected and reconnected the lcd.
    Since the upgrade to 15 we have also had the flickering LCD issue. Have swapped cables and jiggled connectors to no avail. Other issue is that the camera occasionally does not recognize the LCD on boot up resulting in a blank screen. Had the blue screen once but that was solved by a reboot.
    Jim Logan
    Logan Productions, Inc.
    8035 N. Port Washington Road
    Fox Point, WI 53217
    414-352-9691
    jim@loganproductions.com
    www.loganproductions.com
    ramping works, well sorta. Just loaded 2.1.7 in hopes of the ramping working again. It ramps, but once it reaches it's end frame rate, it begins to speed up again. If I remember right, it should continue recording at the selected end frame rate until you stop recording. Happens in 2k 2:1 R28 and R36 as well as 3k 2:1. Anyone else experience this?
